Cooling VRM's
168 (0.10/day)
System Name MonsterBot
Processor AMD FX 6350
Motherboard ASUS 970 Pro Gaming/AURA
Cooling 280 mm EVGA AIO
Memory 2x8GB Ripjaw Savge X 2133
Video Card(s) MSI Radeon 29 270x OC
Storage 4 500 gb HDD
Display(s) 2, one big one little
Case nighthawk 117 with 5 140mm fans and a 120
Audio Device(s) crappy at best
Power Supply 1500 W Silverstone PSU
Mouse Razer NAGA 2014 left handed edition
Keyboard Redragon
Software Win 10
Benchmark Scores none
Is there a consensus on VRM's and cooling with an AIO?
It is my understanding that when one has an air cooler, there is some ambient air flow (by design) across the VRM's. And when one changes it up with a liquid cooler, the VRM'S lose the air flow across them, burn out sooner, and cause a whole host of issues along the way.
I researched this previously on another site, but the answers caused some stupid arguments.
I do have a 140mm fan sucking air off of the VRM's. It blows at the exhaust fan and sits on top of my GPU, which is fine except it looks tacky and it falls over every time I even think about opening my PC.
I also have another 140 on the other side of the case blowing air on the back of the processor socket.
I am sitting at a solid 20% overclock, up from about 15% and debating 25%. I have had it as high as about 30% but didn't keep it there very long as I can't afford to fry something just yet. I know it will go there at least.
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
ive run water coolers for many years, & every water system has just about as many fans as a traditional heatsink. vrm cooling is radiant, a non issue unless youre into extreme OC.
ive never had a vrm burnout, on the contrary, i generally give away my retired components (motherboards included) to fellow TPu members regularly, to continue to serve PC enthusiasts for more years.
168 (0.10/day)
Keyboard Redragon
Software Win 10
I guess I should have made this a poll. Any other answers?
How much do you OC? What do you consider extreme?
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
there is no need for a poll, unless you're looking for opinions instead of answers.
what is your VRM temp with your current OC?
FreedomEclipse
~Technological Technocrat~
24,788 (3.76/day)
(currently) Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
You want something like an Antec Spotcool
But if your case already has good airflow - you wont really need one.
Unfortunately the Antec Spotcool has been discontinued for a long time but some people have gotten creative with the idea and made their own versions with zip ties, rubber bands and wire from clothes hangers -- basically whatever you can get your hands on and make it yourself.
9,781 (2.14/day)
Massachusetts
Processor i7-11700K
you can get these off ebay custom made to your size requirements, but i promise i havent faced vrm temp issues in a long time, & when i did, the heatsink was not attached properly.
1,029 (0.29/day)
Nova Scotia, Canada
Cooling Cooler Master Hyper 212 Plus
Memory 32GB 4x8 G.SKILL Trident Z 3200 CL14 1.35V
Video Card(s) PCWINMAX RTX 3060 6GB Laptop GPU (80W)
Storage 1TB Kingston NV2
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Software Win 11 Pro 64-Bit
Your board has pretty beefy vrm's for any am3+ board, I have the same one and it barely got hot running an FX 8150 @ 5.65GHZ 1.7V on dry ice. Your 6350 will hardly stress it out.
The hottest part on the board is not actually the vrm but the NB since the heatsink is fairly small.
1,610 (0.34/day)
Northamptonshire, UK
System Name Main / HTPC
Processor Ryzen 7 7800X3D / Ryzen 7 2700
Motherboard Aorus B650M Elite AX/ B450i Aorus Pro Wifi
Cooling Thermalright Phantom Spirit 120 EVO / Wraith Spire
Memory Corsair Vengeance 2x16 6000MHz CL30 / HyperX Predator 2x8GB 3200MHz
Video Card(s) MSI RTX 4080 Super Gaming X Slim / ARC A380
Storage WD Black SN770 1TB / Sabrent Rocket 256GB
Display(s) Aorus FO32U2P / 39" Panasonic HDTV
Case Asus AP201 / Cougar QBX
Audio Device(s) Denon AVR-X2800H / Realtek ALC1220
Power Supply Corsair RM1000e / BeQuiet SFX Power 2 450W
Mouse Logitech G903
Keyboard Drop Sense75 with WQ Studio Morandi's
VR HMD Rift S
Software Win 11 Pro 64Bit
When it comes to AM3+ VRM cooling, if your CPU isnt throttling under full load, then it's not an issue.
I had a M5A97 Evo R2.0 way back when, which looks to have the same VRM heatsink as yours, with a 8320 clocked at 4.3-4.4, and that was definitely pushing to its limits, and an extra fan definitely helped it.
But since you're running a 6350, I wouldn't worry too much about it.
Tatty_Two
Gone Fishing
26,029 (3.70/day)
Worcestershire, UK
Software Win 11 Home x64
Any current 240/280/360/480mm Artic Liquid freezer II comes with a bespoke VRM fan.
168 (0.10/day)
Keyboard Redragon
Software Win 10
I saw that myself. I thought any fan that small probably spins fast AF. To me that means noise, which defeats the purpose of liquid cooling, at least for me.
12,340 (2.21/day)
Oregon
Keyboard EVGA / Logitech K400
Just keep the case air moving. Should be fine with that board you don't need active cooling
1,610 (0.34/day)
Mouse Logitech G903
VR HMD Rift S
Had this on mine, an old fan from a P4 cooler, it doesnt need to spin fast to cool, just fast enough to move the air through the heatsink.
9,800 (3.23/day)
System Name Good enough
Case Phanteks NV7
Power Supply GPS-750C
Necessary, not really.
You can always put a fan over them for peace of mind.
Tatty_Two
Gone Fishing
26,029 (3.70/day)
Worcestershire, UK
That's not the case though, I fully understand why you would think that but even gaming at 5Gig I cannot hear it above normal rad fans and GPU fan noise. I suppose that might be because their coolers are good, they have 38mm rads and the VRM/Pump and fans all come off the same 4 pin connector PWM controlled so possibly the heat of the VRM's cannot override the rad fans and pump rpm's, reviews do evidence significant VRM temp drops though up to 20%.
2,199 (0.35/day)
System Name Ryzen7700
Processor AMD Ryzen 7 7700
Motherboard Asus ROG STRIX B650E-F GAMING WIFI
Cooling NZXT Kraken X62
Memory Patriot Viper Venom PVV532G700C32K (32GB @ 6000CL28)
Video Card(s) AMD Radeon RX 6800XT Midnight Black
If you VRM is really running hot, you can try one of these.
VRM exhaust cooling shroud 120mm - https://www.thingiverse.com/thing:2569219
120mm VRM Duct - http://www.thingiverse.com/thing:1492961
140mm x 55mm Duct - http://www.thingiverse.com/thing:2208560
140mm x 40mm Duct - http://www.thingiverse.com/thing:2208591
On my MSI B350 Tomahawk I used the "VRM exhaust cooling shroud 120mm" since the VRMS got pretty hot with 100% load. Atleast 95 degrees and most likely much higher but the sensor couldnt report it :mad:
With the mod, the temperatures drop to +/- 80 degrees with 100% load :rockout:
Toothless
Tech, Games, and TPU!
9,815 (2.42/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Could always get a big, slow moving 200mm fan and hang it over your board. Looks ugly, works beautifully.
212 (0.06/day)
ID_SUB
System Name Asus X450JB
Processor Intel Core i7-4720HQ
Motherboard Asus
Memory 2x 4GiB
Video Card(s) nVidia GT940M
Storage 2x 1TB
Unless you pick cookie cutter budget board or doing gazillion Hz overclocking, it should be fine. Most VRM on enthusiast boards these days are so massively overbuilt that they're not even on 1/4 capacity at typical load.
Your RAM or NVMe SSD probably get more problem from the lack of airflow long before your VRM.
