Core Temp plugin for Lcdsmartie?
3,278 (0.48/day)
UK-small Village in a Valley Near Newcastle
Processor I9 9900KS @ 5.3Ghz
Motherboard Gagabyte z390 Aorus Ultra
Cooling Nexxxos Nova 1080 + 360 rad
Memory 32Gb Crucial Balliastix RGB 4.4GHz
Video Card(s) MSI Gaming X Trio RTX 3090 (Bios and Shunt Modded) 2.17GHz @ 38C
Storage NVME / SSD RAID arrays
Display(s) 38" LG 38GN950-B, 27" BENQ XL2730Z 144hz 1440p, Samsung 27" 3D 1440p
Case Thermaltake Core series
Power Supply 1.6Kw Silverstone
Mouse Roccat Kone EMP
Keyboard Corsair Viper Mechanical
Hi all, since finding out core temp is giving much more acurate temperature readings from my cpu cores than speedfan, I am trying to work out if its possible to send the temperature readings from Core Temp to my lcd display software.
I currently use lcdsmartie ( http://lcdsmartie.sourceforge.net/ ) to display temperatures from speedfan onto my display, and am wondering if any1 knows if its possible to do the same with Core temp, as that would be so handy
Cheers,
Mand
Isn't it possible to get Everest to work on your lcd.
Works great on my G15 keyboard.
hmmm, I didnt realise that, i cant find an everest plugin for lcd smartie, but do u know of another lcd program that may work?
cheers bud
You can always try with Everest. Maybe the G15 support works also for your lcd.
unfortunatly everest just supports the particular display, bah..
Ahh. That's bad. I'm not so in to lcd's, so i really can't give you any advise on this one.
Have you tried google?
its cool bro, i found a somewhat "inneficient"solution. I just offset the core0 temp reading on speedfan by -3C, its not perfect, but close enuff methinks, not as responsive either, but it reads close enough to be functional
Better then nothing.:)
I have the Aerocool frontpanel. That thing is a joke when it comes to reading temps.
It's of more then 10 degrees sometimes.:nutkick:
But it looks cool.:D
