Core Temp released
839 (0.14/day)
System Name GB
Processor Core i7-4790K
Motherboard Gigabyte GA-Z97X-SOC Force
Cooling XSPC RayStorm D5 EX240 (Liquid Ultra)
Memory G.Skill F3-2933C12D-8GTXDG @ 3100 (CL.12) @ 1.66V
Video Card(s) Evga GTS 450SC
Storage 2xSSD Corsair Force GS 128 (RAID 0), WD Caviar Black 1TB
Case NZXT Phantom 630 Ultra Tower
Power Supply Gigabyte Superb 720W
Software Win 7 SP1 x64;Win 8 x64 (6.3)
Core Temp 0.99.6
http://www.alcpu.com/CoreTemp/CoreTemp32.zip
http://www.alcpu.com/CoreTemp/CoreTemp64.zip
- Add: Support for new and upcoming Intel and AMD processors.
- Add: Better recognition of AMD dual/tri core unlocked CPUs.
- Add: Optional 24 hour display on G15 LCD.
- Fix: Platform field blank for newer AMD CPUs.
- Fix: Some K8 CPUs were unknown or recognized incorrectly.
- Fix: Overheat protection "Activate at specified temperature" problems were fixed.
- Fix: Overheat detection does not show a Balloon Tip when user specified temperature value is set.
- Fix: Temperature displays a negative value when core temperature reaches over TjMax (Intel).
- Fix: Intel W3500 series Xeons recognized with Core i7 model numbers (ie W3520 shown as Xeon 920)
- Fix: In certain cases Core 2 Duo T5500 was recognized as a T5450.
- Fix: G15 LCD display is no longer always-on-top after coming out of sleep or hibernation.
- Fix: G15 won't display 0.0000v in case VID readings are not supported by the CPU.
- Fix: In some cases, at Windows startup systemtray icons would not appear.
- Change: Windows XP SP2 or higher is now required.
- Change: Completely new processor frequency detection algorithm. (for Core 2 generation and newer only)
- Change: Remove "APICID" from main window as it has very little use.
*(The upcoming version should fix frequency detection)
this is good
my 1055t is not to be trusted
Core Temp 0.99.7.7
http://www.alcpu.com/CoreTemp/Core-Temp-setup.exe
- New: Core Temp FAQ is now available online, see About Core Temp dialog.
- New: System tray icons for CPU speed and CPU load - see System Tray setup under Options.
- New: Support for the latest mobile AMD processors.
- Fix: Multiple "Fail" messages when the computer exits sleep or plugged into/unplugged from power (laptops).
- Fix: Several mobile Intel processor recognition issues.
- Fix: When disabling Windows 7 Taskbar feature with Cycle mode, icons still continue to cycle.
- Fix: Windows 7 Taskbar settings UI bug.
- Update: "Start with Windows" function in Vista and 7 now works on a per-user basis.
- Update: Change the time and date layout of the log file name to YYYY-MM-DD HH-MM-SS.
- Update: All of the readings logged are now numeric only.
- Update: In single instance mode, the previous instance will be brought to the screen.
- Known issue: Core Temp may stop responding for a period of time or completely lockup on some systems when switching between power supplies (wall/battery) or exiting sleep/hibernation mode.
nice keep as on update , thanx a lot
Core Temp 1.0 RC1
- New: Multilingual interface. Core Temp now natively supports adding non-English languages.
- New: Plugin system - 3rd party developers can now create plugins and extensions for Core Temp, both native code and .Net is supported, please see this for more information.
- New: Added support for Intel Pentium and AMD K5 and newer processors. (detection only, Temperature by Acpi Thermalzones)
- New: Added support for VIA processors. (C3 - detection only, Temperature by Acpi Thermalzones)
- New: Intel Sandy Bridge and AMD Fusion (Brazos, Llano) support.
- New: Max TDP detection on supporting processors.
- New: Power consumption on Intel's Nehalem and newer processors.
- Fix: All of the user reported bugs and many more unreported problems.
- Update: Optimized the startup code, Core Temp should now launch 2 to 4 times faster.
- Update: Optimized many other aspects of the code, Core Temp should now consume much less CPU time than before.
- Update: Restored support for older OS: Windows XP is now fully supported, Windows 2000 requires security updates KB935839, KB835732 and GDI+. In some cases hotfix KB816542 may be needed as well.
Core Temp 1.0 RC2
- Fix: Temperature spikes to TjMax on Sandy Bridge CPUs.
- Fix: Settings not saved properly bug.
- Change: Changed frequency detection back to the original for Intel processors.
- Change: Removed power consumption feature on older CPUs (only supported by Sandy Bridge now).
- Known issues: Occasionally wrong FSB detection (Workaround: Press F5 in Core Temp).
- Known issues: Recognition of Atom E600 series.
Core Temp 1.0 RC3
Version 1.0 RC3 - 25th January, 2012
*** Core Temp Monitor is now available, an Android app to monitor your machines from anywhere in the world! More information can be found here.
- New: Intel Sandy Bridge (SB & SB-E) and AMD Bulldozer and Fusion (Brazos, Llano) support.
- New: Power consumption on Intel's Sandy Bridge (SB & SB-E) processors.
Core Temp 1.0 RC3
I keep getting a error when I click on the links, is their site down?
EDIT: grats on your 300th post :)
Core Temp 1.0 RC4
All downloads:
- New: Intel Sandy Bridge, Ivy Bridge, AMD Bulldozer, Piledriver and Fusion (Trinity, Llano, Brazos) support.
- New: Active power consumption on Intel's Sandy Bridge and Ivy Bridge processors.
It would be nice to see CoreTemp support the Intel Atom processor!!!!!!!!!!!!
It works here, what Atom do you have :)
I think it is the N520 on a Zotac motherboard. Actually I think the last time I tried Core Temp was on a N310 Atom in a Asus board. Read really odd temps. Something like -1C :laugh:
Will give it a shot on the Zotac N520 board.
Thanks for the heads up Derek!
You're welcome & good luck :)
