- Aug 29, 2005
- 7,526 (1.04/day)
- Stuck somewhere in the 80's Jpop era....
System Name | Lynni Zen | Lenowo TwinkPad L14 G2 | Tiny Tiger |
Processor | AMD Ryzen 7 7700 Raphael | i5-1135G7 Tiger Lake-U | i9-9900k (Turbo disaabled) |
Motherboard | ASRock B650M PG Riptide Bios v. 3.20 AMD AGESA 1.2.0.3a | Lenowo BDPLANAR Bios 1.68 | Lenowo M720q |
Cooling | AMD Wraith Cooler | Lenowo C-267C-2 | Lenowo 01MN633 (35W) |
Memory | Flare X5 2x16GB DDR5 6000MHZ CL36 (AMD EXPO) | Willk Elektronik 2x16GB 2666MHZ CL17 | Crucial 2x16GB |
Video Card(s) | Sapphire PURE AMD Radeon™ RX 9070 Gaming OC 16GB | Intel® Iris Xe Graphics | Intel® UHD Graphics 630 |
Storage | Gigabyte M30 1TB|Sabrent Rocket 2TB| HDD: 1TB | WD RED SN700 1TB | M30 1TB\ SSD 1TB HDD: 16TB\10TB |
Display(s) | KTC M27T20S 1440p@165Hz | LG 48CX OLED 4K HDR | Innolux 14" 1080p |
Case | Asus Prime AP201 White Mesh | Lenowo L14 G2 chassis | Lenowo M720q chassis |
Audio Device(s) | Steelseries Arctis Pro Wireless |
Power Supply | Be Quiet! Pure Power 12 M 750W Goldie | Cyberpunk GaN 65W USB-C charger | Lenowo 95W slim tip |
Mouse | Logitech G305 Lightspeedy Wireless | Lenowo TouchPad & Logitech G305 |
Keyboard | Ducky One 3 Daybreak Fullsize | L14 G2 UK Lumi |
Software | Win11 IoT Enterprise 24H2 UK | Win11 IoT Enterprise LTSC 24H2 UK / Arch (Fan) |
Benchmark Scores | 3DMARK: https://www.3dmark.com/3dm/89434432? GPU-Z: https://www.techpowerup.com/gpuz/details/v3zbr |
hmm i got a mkv file i can't decode using CoreAVC 3.0.1 this here is the first one, but if i take "H.264/AVC" in Combined Community Codec Pack - FFDShow Settings i can play it without any issues and same goes for "LAV Video (CCCP)" when i activate that for GPU decoding i get lack or just black screen, but i can also play this mkv file with Arcsoft TotalMedia Theatre 5.3.1.146 without playback issues. (i am using CCCP Beta 2012-02-25)
here is the info from "MediaInfo" in MPC:
can this be driver issues for my Nvidia GeForce GTX 680 2gb?
i am using driver 306.23 WHQL
Code:
General
Unique ID : 9693962732724109731527227487016108047 (0x74AFD4376D8F380E05E18F32016C00F)
Complete name :
Format : Matroska
Format version : Version 2
File size : 3.87 GiB
Duration : 1h 5mn
Overall bit rate mode : Variable
Overall bit rate : 8 455 Kbps
Writing application : XviD4PSP 6.0 / 53.6.0
Writing library : XviD4PSP 6.0 / 53.6.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L3.2
Format settings, CABAC : Yes
Format settings, ReFrames : 3 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 5mn
Bit rate : 6 075 Kbps
Nominal bit rate : 5 755 Kbps
Width : 1 280 pixels
Height : 960 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : MBAFF
Bits/(Pixel*Frame) : 0.198
Stream size : 2.78 GiB (72%)
Writing library : x264 core 116 r2019M 9cc407d
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.20 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=10 / sliced_threads=0 / nr=100 / decimate=1 / interlaced=bff / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=5755 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Audio
Format : DTS
Format/Info : Digital Theater Systems
Format profile : MA / Core
Codec ID : A_DTS
Duration : 1h 5mn
Bit rate mode : Variable
Bit rate : 2 212 Kbps / 1 510 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossless / Lossy
Language : French
