Corsair 760t power button led
66 (0.02/day)
Processor Intel i7 4790K
Motherboard GA-Z97X-UD5H
Cooling be quiet! pure rock
Memory Corsair Vengeance 2x8 1600mhz
Video Card(s) Gigabyte GTX 970 G1 Gaming
Storage Western Digital Black 1TB
Case Corsair 760T
Hello, i have Corsair 760t case and power button have led around it. The LED is always on, but from 2 days the led flickering ( on, off,on,off all the time). I have this case from 3 weeks. The f_panel is 100% plug in correctly. Can someone tell me what can be the problem ?
computer is in sleep mode....
should stay lit if the PC is powered. Check the connection at both ends,at the motherboard, and behind that LED. Seems like a connection issue or broken wire somewhere in the run. I'm sure you could get with Corsair and see if they offer maybe a front bezel replacement, or just the I/O panel can be replaced. Most instances you do not need to swap out the entire chassis to get it fixed.
I check the places that u offer and i think everything is ok.
If you think its the button you can call Corsair and have them send you a new button. But you have to call. But if its in sleep mode it will blink and if its connected to the HDLED it will blink also
I have the same case and my power button stays on solid because it's the PLED.
My reset button is the one that flashes because it's the HDLED.
I'm thinking you these connectors backwards.
I have had mine for 3 months, awesome case I have to say. :pimp:
Nope it`s not backward connectors. Just chance :)
And the case is awesome yes ! :)
