- Oct 9, 2007
- 47,767 (7.42/day)
- Dublin, Ireland
System Name | RBMK-1000 |
Memory | 2x 16GB DDR4-3200 |
Storage | Samsung 990 1TB |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
Cougar brought a couple of its latest cooling products to Computex 2025, besides an innovative new lineup of cases, which we covered here. Starting things off are the Unity ARGB line of compound fans. A compound fan is a single fan frame with multiple impellers that are internally connected for their PWM main function and ARGB lighting. This reduces cable clutter from having individually connect each fan. Compound fans pair best with liquid cooling radiators. The company showcased its Unity ARGB 240 (2x 120 mm) and Unity ARGB 360 (3x 120 mm) compound fans, both of which come in black and white color variants, and come with the ability to forward or reverse their airflow. The frames of these fans not just discreetly wire the subunits, but also serve as ARGB diffusers. Each of the impellers comes with ARGB lighting of their own.
Next up is the Poseidon Vistek Pro line of high-end AIO liquid CPU coolers. These are characterized by large 3.9-inch true-color displays that are mostly square (and hence not from a smartphone spare parts bin). The screen can be made to display just about anything, although its included software puts out system monitoring stats pulled from ACPI. The cooler includes a Cougar Unity ARGB 360 compound fan that shares a common frame among three 120 mm impellers, and hides the associated cable clutter. The frame also has a neatly executed ARGB diffuser, besides the LEDs located in the subunits themselves. The cooler supports all modern desktop CPU socket types, including LGA1851 and AM5.
