CPU core undervolt barely making a difference
sjoerd104
1 (0.00/day)
Hello,
I've set an offset on both CPU Core and CPU Cache which is -155.3mV. I've been using this for ages, but I've just noticed that removing the undervolt on CPU Core makes almost no difference in temps and power usage, 1-2W at most. Whilst the undervolt on CPU Cache makes a massive difference, about 17W and 18°C.
Is this normal?
Thanks a lot :)
Or wait, could they be adjusting the same exact thing and/or overwriting eachother? It seems buggy or somethin, cause if i only UV one of them, it doesn't make a difference, but if i UV both of them, then there's a BIG difference. So basically the UV has no effect if i only do it on one of them (regardless of which one).
