Cpu debug led during flashback bios
47 (0.05/day)
Guys i try to flashback bios and i clicked the button after 2 seconds pc opened and cpu debug led was lightning i try to reset cmos but it didnt work i need ur help
44,288 (6.80/day)
You're going to need to get to a shop with all the trouble you are having with gpus and now your motherboard.
578 (0.32/day)
System Name Mini efficient rig.
Processor R9 3900, @4ghz -0.05v offset. 110W peak.
Motherboard Gigabyte B450M DS3H, bios f41 pcie 4.0 unlocked.
Cooling some server blower @1500rpm
Memory 2x16GB oem Samsung D-Die. 3200MHz
Video Card(s) RX 6600 Pulse w/conductonaut @65C hotspot
Storage 1x 128gb nvme Samsung 950 Pro - 4x 1tb sata Hitachi 2.5" hdds
Display(s) Samsung C24RG50FQI
Case Jonsbo C2 (almost itx sized)
Audio Device(s) integrated Realtek crap
Power Supply Seasonic SSR-750FX
Keyboard Redragon K539 brown switches
Software Windows 7 Ultimate SP1 + Windows 10 21H2 LTSC (patched).
Benchmark Scores Cinebench: R15 3050 pts, R20 7000 pts, R23 17800 pts, r2024 1050 pts.
whats your setup (cpu, mobo, ram, gpu)? Did you cut the power during bios update?
44,288 (6.80/day)
Review this mess.
ir_cow
5,023 (0.83/day)
USA
Depending on the motherboard, flashing lights in normal. Takes 5-6 minutes. Once it is done, the system turns off again. Assuming you have the flash drive formatted to FAT32, named the file correctly and put in the right USB port. If you reset the system mid-flash, now your in some real trouble.
2,100 (0.47/day)
Spencerport NY
System Name Master
Motherboard SR-2 Classified
Video Card(s) EVGA GTX680
Agree with this. You're in over your head.
47 (0.05/day)
Anakarta bağlı olarak, yanıp sönen ışıklar normaldir. 5-6 dakika sürer. Tamamlandığında, sistem tekrar kapanır. Flash sürücünüzü FAT32 olarak biçimlendirdiğinizi, dosyayı doğru adlandırdığınızı ve doğru USB bağlantı noktasına taktığınızı varsayalım. Sistemi flaşın ortasında sıfırlarsanız, şimdi gerçekten başınız belada demektir.
No i clicked flashback bios button after 2 seconds pc turned on and cpu debug led was red and i waited 10 minutes pc didnt boot.
Shops are scammer.They stealing pc parts and even if they dont fix they still take so much money.
Mussels
Freshwater Moderator
58,412 (7.77/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
You keep making new threads without resolving anything in the others
BIOS flashback has a list of required steps - so list the ones you did. How'd you format the drive, what file is on the drive under what name, what USB drive is it, what port did you connect it to
47 (0.05/day)
Diğerlerinde hiçbir şeyi çözmeden yeni konular açmaya devam ediyorsunuz.
BIOS flashback'in gerekli adımların bir listesi vardır - bu yüzden yaptıklarınızı listeleyin. Sürücüyü nasıl biçimlendirdiniz, sürücüde hangi adla hangi dosya var, hangi USB sürücü, hangi bağlantı noktasına bağladınız?
it was fat32 but i guess it was gpt i put my usb to flashback port and installed last version of bios now cpu debug led on and pc wont boot i tried to clear cmos flashback another bios version but flashback doesnt work lights keep flashing for minutes.
My cpu r5 3600 motherboard msi b550 gaming edge wifi
Mussels
58,412 (7.77/day)
Oystralia
It needs to be MBR and FAT32
The light is MEANT to flash for several minutes, that means its flashing usually
What BIOS file did you flash, and what did you name it
47 (0.05/day)
MBR ve FAT32 olması gerekiyor
Işığın birkaç dakika yanıp sönmesi GEREKLİDİR, yani genellikle yanıp söner
Hangi BIOS dosyasını flash yaptınız ve adını ne koydunuz?
MSI.ROM 7C91v18 bu, ikinci denediğim sürüm, ilk önce 7c91v18'i denedim.probably my usb wasnt mbr cuz flash was blinking til i close the power
5,685 (1.02/day)
Gougeland (NZ)
System Name Cumquat 2021
You need to remove and re partition the USB stick to an MBR type partition and format as FAT32
then copy over the correctly named bios file
plug the USB stick into the BIOS Flashback port and click the button again
wait for the PC to turn off after the flash has been done
power on the PC enter BIOS/UEFI make sure everything's ok
this should work even if you fucked it up the first time as the software to flash the BIOS is contained in an read only part of the ROM so doesn't require a properly flashed BIOS/UEFI to work
47 (0.05/day)
i try but i couldnt see bios before update cuz my gpu gop is broken so i cant get to the bios.Even if i flashed i hope it will work.
And how can i format my usb mbr and fat32
