cpu fan error
47 (0.03/day)
so hello guys I am new to the forums and i have a problem i can't solve that I get error message CPU error fan and it won't make the pc boot and when i press F1 to enter bios settings it give me for about 10 sec before the pc freeze in bios settings and i must restart it and same problem every time and the only way to boot pc and go to windows is that i must choose manually the boot drive from bios settings before it freezes also i face high processor temp when i try to play games it reaches 105 c so can anyone pls help me
my pc
intel core i7 3770
gigabyte wind force 2060 RTX
16 GB ram ddr3 bus 1600
Asus p8z77-v deluxe
corsair vs 650 power supply
the error is usually based on fan speed, and when the motherboard sees none, it alarms.
You need to visually check to see if the CPU cooler fan is turning, or see if it is packed with dust.
What cooler are we dealing with here?
Without knowing what you see inside, maybe get a picture so we can better assist you, it is still tough to advise a course of action thus far.
What he said ^^^^^
Also make sure you didn't accidently pull the CPU fan lead from the Motherboard.
thank you for helping guys i just clean the fan and the processor and it works i dont get the massage i face now another problem that my pc is rebooting when i go and play gmaes and make load onthem with games and ti sometimes happen and sometimes not what may cause the pc to do that gpu or the power supply unit
Check the in-game temperatures with GPU-Z or HWMonitor. Maybe the CPU cooler isn't mounted correctly.
103c is extremely hot and likely to trigger a shut down to protect the CPU. Reapply thermal paste and remount the CPU cooler. Make sure the fan is spinning normally. 80c is above average for a GPU.
ok my cpu iam thinking for getting new cpu cooler like
Thermaltake Contac 9 CPU Cooler
but my gpu version is gigabyte 2060 rtx windforce 2 fans edition and and i read that this one reach this temp due to there bad cooling system so i try my best to cool it with case airflow
the problem is it workes normally when i play games on 1080p but when i try to play at 1440p or active RTX in some games it make this reboot so i really dont knowif it from psu or gpu or cpu and thanks for help me
Fix the CPU temperature issue first, then the rest we can look at later.
That's not a fantastic CPU cooler, but not terrible either. I get very mediocre results with the Cryorig M9 on my 2600k... but it works.
Did you actually remove the cooler from the processor? Did you clean the old thermal paste off and apply new? Are you sure the cooler is mounted correctly? Those push pins can be tricky and sometimes they may not be fully inserted, pop back out, or even break.
ok u was right guys the cpu cooler was not mounting right i think i fix it and now it get from about 70 to 80 in normal games and get from 80 to 92 in Assassin's Creed Odyssey as it use about 90% from the cpu like pic
Temps are still high, but that's about what I'd expect from a dinky stock cooler on that chip... especially if case airflow is bad.
yes as u say its a dinky stock cooler but i think this temp now not the reason for rebooting the pc so if this happens again what may cause that
Get a better CPU cooler and check the case fans (if there any). Replace the old ones, and add new fans if possible.
so guys thanks for the help I solve my rebooting problem it was this PSU I get a new one Thermaltake 730 w bronze but I still with the problem of CPU temp as it hot in my area these days and CPU return to get 102 c in some games so any suggestions for good CPU cooler and cheap as my case not helping me in airflow as it an old one nzxt lexa s
guys I get fsp windale 4 CPU cooler and I get about 66 c on using 50% and get about 87 c with 100% is that normal or like that I have a problem in the CPU with temp in the room about 21 c to 25 c
can u confirm to me is that normal or not and another info I have nzxt lexa s case
According to the following review:
https://www.techpowerup.com/review/fsp-windale-4/
87c is still to hot for stock i7-3770 and just gaming.
Did you put thermal paste between the cooler and CPU?
Is it installed properly?
Do you have fans inside the case? Post a photo of your case.
How do you measure temperatures? with what software?
ok yes I apply thermal paste and yes I install it right I measure temperatures with MSI Afterburner inside the game and here the photo
How are the case fans setup? Are there any fans in front or at the bottom?
the case is old one so there is only one fan can be set up in front of the case and it at the right of the HDD and another one with I manage to place in front of CPU cooler it the one with blue led
I’d recommend using the side/window intake fan if you can and flipping those top fans to intake.
Don't know the proportions of the photo.
Looks lke 3 exhaust Zalman fans, some dust, and a very small PC case.
I suggest you upgrade to a bigger case. Until then, use cable ties to organize cables to maximize airflow.
so I reapply the top fans to intake fan and mange cable as possible and now after play Assassin's Creed Odyssey for about 3 hours max temp I get with CPU is 75 c and make stress test with prime 95 for about 20 min max temp it reaches is 82 c is that good guys
