CPU Fan spinning out of control and freezing my computer??
bubs
120 (0.02/day)
UK
System Name Bubs
Processor Phenom ii X6
Motherboard Gigabyte GA-880GM-UD2H 880G
Cooling Stock Fan
Memory 8GB Corsair 1333MHz
Video Card(s) ATI 4890 2GB
Storage 650GB + 2TB
Display(s) 23" HD LG Monitor 1920x1080
Case Antec VSK 2000
Audio Device(s) Intergrated
Power Supply Corsair 850 Watt
Software Win 7 UltimateDead Island + Deus EX
Hi Again
I had a fault about two weeks ago and thought id fixed it. Basically I just using my computer playing dragonage I think it was when the this really load spinning noise started, and my computer screen lost its picture and then froze I opened the side panel to see the CPU fan was spinning really fast., I powered it off, then back on again. I went into the bios and tweaked with the cpu fan settings. Now its been fine for two weeks now and all of a sudden i was on the internet while something was unzipping and my fan when spinning mad again. I powered off and on again to find that the sound is not working now. Does anyone know what is causing this, I am at my wits end on what to do with this pc.
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Its overheating, make sure the heatsink and fan are seated properly.
Frick
Fishfaced Nincompoop
20,054 (2.86/day)
norr
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
How are the temperatures?
5,269 (0.86/day)
System Name [Daily Driver]
Processor [Ryzen 7 5800X3D]
Motherboard [MSI MAG B550 TOMAHAWK]
Cooling [be quiet! Dark Rock Slim]
Memory [64GB Crucial Pro 3200MHz (32GBx2)]
Video Card(s) [PNY RTX 3070Ti XLR8]
Storage [1TB SN850 NVMe, 4TB 990 Pro NVMe, 2TB 870 EVO SSD, 2TB SA510 SSD]
Display(s) [2x 27" HP X27q at 1440p]
Case [Fractal Meshify-C]
Audio Device(s) [Fanmusic TRUTHEAR IEM, HyperX Duocast]
Power Supply [CORSAIR RMx 1000]
Mouse [Logitech G Pro Wireless]
Keyboard [Logitech G512 Carbon (GX-Brown)]
Software [Windows 11 64-Bit]
definetly sounds like overheating. Is your heatsink/case full of dust?
bubs
120 (0.02/day)
UK
System Name Bubs
Cooling Stock Fan
Storage 650GB + 2TB
Case Antec VSK 2000
Not sure about temp to be honest. What would be my best program to try? Software Sandra? Also no the computer is about 2months old maximum.
sneekypeet
not-so supermod
29,709 (4.27/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
bubs
120 (0.02/day)
UK
System Name Bubs
Cooling Stock Fan
Storage 650GB + 2TB
Case Antec VSK 2000
i just checked the bios and it says the temp is 30c. and the fan is running at 909 RPM.
brandonwh64
19,542 (3.42/day)
normally when the fan speeds get higher means the temps are getting higher. Keep the temp monitoring program running and start going stuff that makes the fan go higher like you described. if it freezes and locks up and the temps high then you need to reset your current cooler or get a better one
sneekypeet
not-so supermod
29,709 (4.27/day)
System Name EVA-01
bubs
120 (0.02/day)
UK
System Name Bubs
Cooling Stock Fan
Storage 650GB + 2TB
Case Antec VSK 2000
Ok I have now unzipped the same 3 things as before, and I have windows explorer on and running dragonage, and these are my temps according to temp gt 360, What else can i do to get my CPU going mad?
sneekypeet
not-so supermod
29,709 (4.27/day)
System Name EVA-01
Even if you ran something like Intel Burn Test (IBT) those temps aren't going to climb into the danger zone.
bubs
120 (0.02/day)
UK
System Name Bubs
Cooling Stock Fan
Storage 650GB + 2TB
Case Antec VSK 2000
i cant understand it? i dont heavily use this computer really. there two case fans running at max and my cpu fan, but the case dont seem hot, seems fine. im at a loss.
sneekypeet
not-so supermod
29,709 (4.27/day)
System Name EVA-01
can you get us a similar shot with GPU-z? (link in post #9)
Also I just noticed Corsair and Gigbyte, is this a new system, have you set the ram voltage and timings, or at least verified the ram is stable?
bubs
120 (0.02/day)
UK
System Name Bubs
Cooling Stock Fan
Storage 650GB + 2TB
Case Antec VSK 2000
yes i have set ram voltage to 1.65 i think. heres gpu
sneekypeet
not-so supermod
29,709 (4.27/day)
System Name EVA-01
ok click the bottom box in the right window that says keep refreshing in the background, leave it open, and play a little, then get an image with loaded GPU temps please.
Just trying to help rule out the obvious culprits;)
bubs
120 (0.02/day)
UK
System Name Bubs
Cooling Stock Fan
Storage 650GB + 2TB
Case Antec VSK 2000
ok, Im going to play black ops for about 10 mins :)
bubs
120 (0.02/day)
UK
System Name Bubs
Cooling Stock Fan
Storage 650GB + 2TB
Case Antec VSK 2000
Ok i just played a bit of BO on highest every thing, screen res 1920x1080 and below i have took a screen of the gpu-z on highest.
sneekypeet
not-so supermod
29,709 (4.27/day)
System Name EVA-01
temperatures look fine on both the CPU and GPU, I have to think its either the memory playing up or software at this point (IE Drivers are messed up, PC may need a reg clean/defrag, something along those lines.
bubs
120 (0.02/day)
UK
System Name Bubs
Cooling Stock Fan
Storage 650GB + 2TB
Case Antec VSK 2000
will try a couple of those things, or i might just sell the parts individually, only had it 2 months and am already peed off with it. cheers for you help sneekypeet
sneekypeet
not-so supermod
29,709 (4.27/day)
System Name EVA-01
Well I see a few people over at TweakTown in the Gigabyte section have had issues with Corsairs newer 1600 memory, so it could be just as simple as the ram isn't stable in that board.
I myself just had issues with a low latency kit on both my P55 boards. I sent them to an ASUS user to see if it is my board or the memory, still waiting for shipping to reach the north pole though.
Are you on the latest bios for that board?
bubs
120 (0.02/day)
UK
System Name Bubs
Cooling Stock Fan
Storage 650GB + 2TB
Case Antec VSK 2000
yes i have updated my bios. I have just tinkered round with the ram settings in the bios and gota BSOD on start up. Now i have gone back to the bios and loaded defaults. and it seems stable. but im only running my 1600 ram at 1066. I think im guna sell the parts individually and just stick with consoles.
brandonwh64
19,542 (3.42/day)
sometimes you have to get the gremlins out :)
hat
Enthusiast
21,753 (3.23/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Quite a troubling issue... maybe the motherboard is bad. Fans tend to spin really fast at system startup, before the BIOS kicks in and impliments fan speed control... it sounds to me like your motherboard is rebooting itself.
You know what, check your northbridge temps. Get hwinfo32 and prime95 and watch the nb temps... for me, it's MCP.
bubs
120 (0.02/day)
UK
System Name Bubs
Cooling Stock Fan
Storage 650GB + 2TB
Case Antec VSK 2000
@hat ok will do that tomorrow now. I have been in the bios now and rest my ram to default just incase that was causing it to be unstable. But its really weird, you hear a rapid spinning noise like the computer was going to blow up then it would only stop when i powered off the computer. I really cant see it being a RAM problem tho :(
Sadasius
263 (0.04/day)
Ottawa, Ontario
System Name "White Ghost"
Processor i7 970 watercooled
Motherboard Rampage III Extreme all watercooled
Cooling Custom Water Cooling. You have to see it. Too many parts to list here!
Memory 12GB Corsair Dominator GT's watercooled
Video Card(s) HD 5850....watercooled!
Storage Gskill Phoenix Pro 120gb and several 500gb and 1 tb hdd's.
Display(s) Dual 24" Asus VW246H mounted to the wall
Case CM Storm
Audio Device(s) Sound Blaster Audigy
Power Supply Ultra X3 1000
Software Windows 7 64 Ultimate
Benchmark Scores http://valid.canardpc.com/2551267
Should hear my rad fans when my computer restarts. It is like it will hover away on me literally! Click the links in my sig if you don't believe me..... I dares ya! :D
