I've just build a pc. I changed the mobo, cpu, and rams. The rest was from the old parts.
I've also got a watercooling (my first time with water cooling)
First time a turned the Pc on , was with the all the system i was using before (same windows), i've just installed the mobo drivers an cpu drivers. Also before everything i've flashback the asrock bios to 3.01 version.
Now I formatted the PC and I have a new system with Windows 11, I installed all the drivers but the problem persists
What is happening is when i connect a USB pen, sd card or external disck the temperature of the cpu goes to 80º, after i take the usb it goes back to normal.
I'm seeing the cpu temperature on the Cooler master software of the watercooling.
My pc:
B650 Pg Lightning
Ryzen 5 9600x
32GB Vengeance
Rx 7800xt
Cooler Master ML240
What could be causing this?
Can i use a more recent version of the BIOS ?
My pc:
B650 Pg Lightning
Ryzen 5 9600x
32GB Vengeance
Rx 7800xt
Cooler Master ML240
