CPU/GPU loop with Swiftech H220
Norton
Moderator - Returning from the Darkness
14,104 (2.88/day)
Northeast USA
System Name Main PC- Gamer- Main Cruncher/Folder and too many crunching/folding rigs
Processor Ryzen 5900X- Ryzen 5950X- Ryzen 3950X and etc...
Motherboard Asrock X570 Extreme4- MSI X570S Tomahawk MAX WiFi- MSI B450M Bazooka Max and etc...
Cooling Noctua NH-U14S (dual fan)- EK 360 AIO with push/pull fans- Corsair H115i RGB Pro XT and etc...
Memory 2x16GB GSkill FlareX 3200/c14- 4x8GB Corsair Vengeance 3600/c16- 2x16GB Team 3600/c18 and etc..
Video Card(s) MSI Gaming RX 6800- Asus RTX 3070 TUF OC- MSI Ventus GTX 1660Ti and etc...
Storage Main PC (1TB WD SN850- 2TB PNY CS 3040- 2TB Seagate Firecuda) and etc...
Display(s) Main PC (2x24" Dell UltraSharp U2414H)
Case Phanteks P600s- Seasonic Q704- Fractal Meshify C and etc...
Audio Device(s) Logitech Z625 THX 2.1 speakers
Power Supply EVGA 750 G3- SeaSonic DGC 750- EVGA P2 850 and etc...
Mouse G300s
Keyboard Corsair K65
VR HMD N/A
Software Windows 10 Pro or Ubuntu
Benchmark Scores Why sit on the Bench when you can get in the game and Crunch!!!
I'm prepping a project build using....
- Fractal Define R4 case
- Asus M5A97 Evo/FX-8350
- Swiftech H220 AIO + Swiftech XP 120mm rad
- PowerColor LCS 7970
- misc tubing, fittings, etc (3/8"x1/2" size)
Here's a draft of the loop:
*white arrows- water flow, blue arrows- air flow
I'm a noob in water cooling so please let me know what you think- Thanks! :)
I'm Not sure if the H220 is beefy enough for this? I've never used one of the self contained water cooling prebuildt units but I thought one of the benefits was that there is no mess no leak.
If your willing to build something from that thing ....may as well go balls first and come correct.
I would recommend the Swiftech H20-220 w that 120mm Rad as a starter kit.
http://www.performance-pcs.com/cata...oduct_info&cPath=59_202_604&products_id=32745
The h220 has plenty of pump power. He really only needs 2x120mm of rad to get good temps. 3x120 of good rads with good fans will make everything temps just great. I share a good 240mm rad with good fans between my 2500k and 7970. My 7970 never gets past 37c.
I already own the H220 so nothing extra to buy in that department ;)
The pump in this unit is oversized for running CPU/GPU(s)/Radiator(s)
Video here shows this unit running dual GTX 680's and dual Radeon 7970's (with an extra 240mm rad)
[yt]4-ly5nKc7ok[/yt]
The extra 120mm rad should cover the extra heat from the 7970 so it should run fine.... If not, keep an eye out for an H220 in the B/S/T section about 10 days from now :o
I've got one of their older systems sitting here with one of their 2x120mm rads, it's heatsoaking pretty quickly off a 3.9ghz clocked 1090T alone. The rad is a fairly decent rad just around 15-FPI (I think) which means beyond a certain point more air flow does very little to reduce temps.
I think if you don't plan to OC you might be alright, however you may find yourself wanting to add another 120mm rad so you can keep temps low and possibly avoid needing to use high speed (noisy) fans.
I'm not sure how the new rad differs from the previous kit they sold.
