SomalianViking
- Mar 8, 2007
- 1 (0.00/day)
Processor | AMD Athlon XP 2500+ |
Motherboard | POS Acorp ??? |
Cooling | Stock HSF w/bad bearing |
Memory | 1GB PC2700 |
Video Card(s) | Nvidia GeForce 5600 Ultra |
Storage | (1) W.D. 160GB; (1) Seagate 40GB |
Audio Device(s) | Sound Blaster Audigy |
I have a question about installing a new Heatsink/Fan combo on my mobo. This is my first time doing a complete build from scratch. Before I have always bought barebones and such that were already 1/2 built. I just bought an ASUS A8N32-SLI mobo with an Opteron 185 processor. That really doesn't matter though; the problem is that the heatsink I bought for it is a gigantic thermaltake that screws into the rear retention bracket instead of clipping into the front bracket like the stock AMD HSF.
If you don't know which heatsink I'm talking about you can see it here:
http://www.newegg.com/Product/Product.asp?Item=N82E16835106061
http://www.thermaltakeusa.com/product/cooler/retail/cl-p0114/cl-p0114.asp
The problem is that I cannot get the heatsink to stay still on top of the processor while tightening the two screws on the retention bracket; thus making a mess of the thermal grease. I know that you're supposed to apply the heatsink carefully from the top down. I've finally gotten it tightened down but I am curious as to whether it will still cool properly after moving back and forth so much. The heatsink probably moved up to 1/2" in either direction numerous times. From what I've heard small rotational movement is ok, but sideways or directional movement messes up the seated thermal compound. Can anyone confirm whether I can leave it or whether I have to pull it back off and re-apply everything?
And as a note: If I have to pull this thing off and do it again, I'll definitly get an extra pair of hands.
