CPU is supposed to be OC'd to 4.5GHz, CPU-Z only reports 3.7GHz
2,365 (0.44/day)
Marlow, ENGLAND
System Name Chachamaru-IV | Retro Battlestation
Processor AMD Ryzen 9 5900X | Intel Pentium II 450MHz
Motherboard ASUS ROG STRIX X570-F Gaming | MSI MS-6116 (Intel 440BX chipset)
Cooling Noctua NH-D15 SE-AM4
Memory 32GB Corsair DDR4-3000 (16-20-20-38) | 512MB PC133 SDRAM
Video Card(s) nVIDIA GeForce RTX 4070 FE | 3dfx Voodoo3 3000
Storage 1TB WD_Black SN850 SSD (OS), 3TB Toshiba (Storage), 8TB Seagate FireCuda/2TB WD_Black SN580X (Steam)
Display(s) Samsung Odyssey G5 27" @ 1440p144 & Dell U2412M @ 1200p60
Case SilverStone Seta A1 | Beige box
Audio Device(s) Creative Sound Blaster AE-7, Edifier speakers, Grado Labs SR80 X headphones | Sound Blaster AWE64
Power Supply EVGA Supernova 750 G2 | 250W ASETEC
Mouse MX Master 3S| Microsoft Serial Mouse v2.0A
Keyboard Vortex Race3 | Dell AT102W
Software Microsoft Windows 11 Pro | Microsoft Windows 98SE
Back when I bought all this stuff and set it up, my buddy crazyeyesreaper had exactly the same stuff as me (minus the GPU and drives), so he told me how to overclock it to match what he did. He told me it would up the clock to 4.5GHz and in future I could go higher if I wanted because I was watercooled. However, CPU-Z has always reported it as 3.7GHz, and I just ran Prime95 to stress the CPU (as advised by a step-by step guide I found to finding your CPU's max clock speed), but it still didn't go above 3.7GHz. What gives?
Tatty_Two
Gone Fishing
26,029 (3.70/day)
Worcestershire, UK
Software Win 11 Home x64
You probably just have one setting wrong in your Bios, is Turbo boost enabled? What core setting do you have? Not knowing your board, I can set mine to "fixed", "all cores" or "per core" for example, and do you have the performance power profile set in windows? There is a start at least!
1,610 (0.34/day)
Northamptonshire, UK
System Name Main / HTPC
Processor Ryzen 7 7800X3D / Ryzen 7 2700
Motherboard Aorus B650M Elite AX/ B450i Aorus Pro Wifi
Cooling Thermalright Phantom Spirit 120 EVO / Wraith Spire
Memory Corsair Vengeance 2x16 6000MHz CL30 / HyperX Predator 2x8GB 3200MHz
Video Card(s) MSI RTX 4080 Super Gaming X Slim / ARC A380
Storage WD Black SN770 1TB / Sabrent Rocket 256GB
Display(s) Aorus FO32U2P / 39" Panasonic HDTV
Case Asus AP201 / Cougar QBX
Audio Device(s) Denon AVR-X2800H / Realtek ALC1220
Power Supply Corsair RM1000e / BeQuiet SFX Power 2 450W
Mouse Logitech G903
Keyboard Drop Sense75 with WQ Studio Morandi's
VR HMD Rift S
Software Win 11 Pro 64Bit
It sounds like your turbo boost option is disabled in the BIOS. I'm pretty sure I've done that same mistake myself before :D
620 (0.15/day)
System Name Headshot
Processor AMD Ryzen 7 3800X
Motherboard ASUS Crosshair VI Hero ROG
Cooling Phanteks Glacier One 360 MPH
Memory 2x16GB Corsair Vengence LPX DDR4 @ 3200 16-18-18-18-36
Video Card(s) AMD Radeon Vega64 (Linux)/Gigabyte RX 6600 (Windows VM)
Storage Cruscial P5 1TB nVME, Samsung 850 EVO 250GB, Seagate 1TBx2 (Home/Data), 2TB Seagate (Games)
Display(s) 2x Acer 1080P 144HZ
Case Phanteks Enthoo Luxe White
Audio Device(s) Schiit Stack (Schiit Audio Modi 2 DAC + Magni 3 AMP + Loki)
Power Supply eVGA Supernova 1000 G2
Mouse Razer DeathAdder V2
Keyboard Logitech G710+
Software Arch Linux with Windows 10 Gaming VM
Have you disabled power saving features and see if that changes your clock speed? I am assuming you have overclocked via multiplier right?
2,365 (0.44/day)
Marlow, ENGLAND
Been talking it over with crazy, he walked me through everything I needed to do. Upped the voltage, changed the multipliers, but the 4 core ratio limit keeps getting backed off to 37. Damn weird.
CAPSLOCKSTUCK
Spaced Out Lunar Tick
8,578 (1.93/day)
llaregguB...WALES
System Name Party On
Processor Xeon w 3520
Motherboard DFI Lanparty
Cooling Big tower thing
Memory 6 gb Ballistix Tracer
Video Card(s) HD 7970
Case a plank of wood
Audio Device(s) seperate amp and 6 big speakers
Mouse cheap
Keyboard under going restoration
check your W7 power saving options too
if things aent going as expected, reset cmos, start again.
620 (0.15/day)
2,365 (0.44/day)
Marlow, ENGLAND
Power plan is set to high performance. I just upped the voltage again to 0.070 and it still backed off to 37 after a reboot.
620 (0.15/day)
But did you check your BIOS options like I stated above.
2,365 (0.44/day)
Marlow, ENGLAND
I disabled C1E and set the multi to 40 and it backed it off to 37 after a reset. Shall I try disabling Turbo Boost and enabling fixed CPU ratio and setting that to 40?
620 (0.15/day)
Yes, that is what Anandtech was talking about. Certainly disable turbo boost and enabling fixed CPU ration.
2,365 (0.44/day)
Marlow, ENGLAND
Okay, I seem to have sorted it. I set it to fixed ratio and 42, and it backed off to 37 again, I upped the voltage and set it back to 42 and it stuck. Now I'm just seeing how far I can push it. Seems like AnandTech were right, 4.8GHz renders the OS unstable. Though I don't know where they got their voltages from, if I set mine to the voltages listed in the article, the numbers turn blue, which I assume means it's too low. Right now it's 1.280v at 4.7GHz and they recommend 1.180v. OS seems a bit unstable when running Prime95, and I got a temperature warning from my CPU monitor. What voltage would you guys recommend?
3,014 (0.62/day)
Zagreb, Croatia
System Name Windows 10 64-bit Core i7 6700
Processor Intel Core i7 6700
Motherboard Asus Z170M-PLUS
Cooling Corsair AIO
Memory 2 x 8 GB Kingston DDR4 2666
Video Card(s) Gigabyte NVIDIA GeForce GTX 1060 6GB
Storage Western Digital Caviar Blue 1 TB, Seagate Baracuda 1 TB
Display(s) Dell P2414H
Case Corsair Carbide Air 540
Power Supply Corsair TX v2 650W
Mouse Steelseries Sensei
Keyboard CM Storm Quickfire Pro, Cherry MX Reds
Software MS Windows 10 Pro 64-bit
I wouldn't do that.
Enable turbo boost and disable fixed cpu ratio.
Use all power saving features and set multipliers here (scroll lower in O.N.E. menu):
2,365 (0.44/day)
Marlow, ENGLAND
If I use Turbo Boost, 4 Core Ratio Limit keeps falling back to 37.
620 (0.15/day)
I wouldn't do that.
i was just going by what the Anandtech article stated. If you own the board then thanks! Turbo boost I dont under stand, if you are overclocking to or beyond the Turbo profile, then having it enabled makes to sense to me, as it will dynamically adjust the multiplier. Every guide I have ever read has said to disable turbo when multiplier overclocking, I guess it could have some merit when overclocking via base clock :confused: I will admit, my knowledge of intel overclocking is zilch, my last intel CPU was a 486 DX2 66 :)
2,365 (0.44/day)
Marlow, ENGLAND
I don't know how far I can push the voltage, so I don't want to just keep increasing it to see if the overclock sticks with Turbo Boost on. I'll be very annoyed if my enthusiast CPU can only achieve an overclock of 200MHz.
Tatty_Two
Gone Fishing
26,029 (3.70/day)
Worcestershire, UK
Fixed option?
2,365 (0.44/day)
Marlow, ENGLAND
Fixed core ratio worked, but I was told by somebody not to use it.
620 (0.15/day)
If it does what you want then...that's how the Anandtech article I posted for your motherboard performed their manual overclock, I would say it is safe. May cause slightly higher power consumption due to not being able to down-clock and under-volt but I doubt your power bill will reflect it.
rtwjunkie
PC Gaming Enthusiast
14,034 (2.29/day)
Louisiana
Processor Core i9-9900k
It all depends on what you want. If you want that speed full time then fixed ration and turning off turboboost is what you want.
3,014 (0.62/day)
Zagreb, Croatia
Cooling Corsair AIO
2,365 (0.44/day)
Marlow, ENGLAND
It's got the latest BIOS, which is a beta version. The thing is, no matter what voltage set it always falls back to 37 on the 4 core ratio. I don't want to set it too high in case it over-volts the chip.
Tatty_Two
Gone Fishing
26,029 (3.70/day)
Worcestershire, UK
I have mine on fixed with turbo boost, does not appear to be any problems, to be honest have never checked if all 4 cores are running at max frequency all the time, I have all the power saving features enabled.
620 (0.15/day)
Setting voltage does not change the multiplier. Voltage is for stability only, increased voltage also has the side effects of increased power draw and increased heat output. Power saving and turbo boost are what can change the multiplier. Leave your multi to fixed and call it a day.
cadaveca
My name is Dave
17,238 (2.48/day)
Get rid of the BETA BIOS, go back to the most recent non-beta, see if that helps.
You should not have to disable Turbo. Disabling Turbo doesn't disable anything... It actually forces the Turbo mode 100% of the time. Without Turbo, these CPUs cannot access multipliers higher than the stock non-turbo multi, so the "workaround" that the BIOS does is force Turbo permanently.
