CPU not reaching 100% usage whilst playing Valorant
mumenrider
6 (0.01/day)
I've been trying to reach constant 144fps whilst playing Valorant or LoL but somehow I can't. I hover at around 120-130fps with constant frame drops. My GPU and CPU usage doesnt go over 50% whilst playing, so it cant be possibly bottlnecked by my CPU right? When playing other games like Tekken 7 and Naruto NInja Storm 4 I can push my GPU usage to 100%. Here are my PC specs, any help would be appreciated. Thanks in advance.
CPU: i7 4790
GPU: AMD HD7870 2GB
RAM: 2x 4GB 1600mhz DDR3 Hyper X Fury Dual Channel
PSU: 600W
9,828 (3.41/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
I don't know of any Ganes that pushes 100% of CPU usage.
9,828 (3.41/day)
Cooling In Win SR36
You are using a card that was a previous Gen before the Game released. Your 2 GB Frame buffer is probably the culprit.
FreedomEclipse
~Technological Technocrat~
24,781 (3.76/day)
(currently) Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
A quick google shows that the game is CPU bound.
A guy on reddit went from a Quad Core Intel to a AMD 3600X and the problem went away - He also had a GTX1660 so it shouldnt be a frame buffer issue.
Try tabbing in and out of the game a few times or switch from borderless to full screen mode in the game settings and see if that helps.
Either way. If a game engine likes more cores - Either play at a lower res/video quality or get a new CPU with more cores or a new setup. Some engines do like more threads, thats just how the cookie crumbles.
44,274 (6.80/day)
Time for an upgrade
ARF
4,677 (2.44/day)
100% CPU utilisation will result in micro-stutter - it is bad not good thing to want...
To OP - can't you simply lower a setting or two?
3,105 (2.01/day)
Germany
Processor AMD Ryzen 9 9950X3D
Motherboard ASRock B850M PRO-A
Cooling Corsair Nautilus 360 RS
Memory 2x32GB Kingston Fury Beast 6000 CL30
Video Card(s) PowerColor Hellhound RX 9070 XT
Storage 1TB Samsung 990 Pro, 2TB Samsung 990 Pro, 4TB Samsung 990 Pro
Display(s) LG 27GS95QE-B, MSI G272QPF E2
Case Lian Li DAN Case A3 Black Wood Edition
Power Supply Corsair RM1000X ATX 3.1
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
because your CPU does not reach 144 FPS?
ir_cow
5,013 (0.82/day)
USA
I know this game can run on a potato. The screenshot makes it look like you are v-synced at 144Hz. Which is why you GPU is sitting at 40% usage in Valorant at least.
mumenrider
6 (0.01/day)
i had uncapped framerate and max settings ,but my gpu usage never exceeded 50-60%
44,274 (6.80/day)
3,936 (1.73/day)
UK, Midlands
System Name Main PC
Processor 13700k
Cooling Noctua NH-D15S
Memory 32 Gig 3200CL14
Display(s) LG 27GL850
Case Fractal Define R4
Software Windows 10 21H2 LTSC
CPU: i7 4790
GPU: AMD HD7870 2GB
PSU: 600W
Not all games can use all cpu cores, which they need to do so to fully utilise a chip, in fact most games I play are 1-4 threaded.
Also its generally not a good idea to max out cpu's in games.
If you cannot get constant frame target and assuming you dont have VRR to prevent stutters/tear, then better to lower the refresh rate to a target you can hit such as 120hz or 60hz. I doubt 144 is noticable over 120, so I would just drop refresh rate to 120 for this game.
mumenrider
6 (0.01/day)
so my old Gpu (GTX 750) was good enough with the setup? i could play 100-120 fps somehow.I upgraded it from a GTX 750 to amd hd7870 to play more than 120fps
3,936 (1.73/day)
UK, Midlands
System Name Main PC
Processor 13700k
You need to analyse the cpu utilisation on each core to get an idea of the number of threads in the game. Also ask yourself can you honestly tell the difference on 144 vs 120? The higher refresh rate goes the less noticeable it will get. But if you really really want that 144, then analyse whats going on with the load of the game. I have more games that are cpu bound than gpu bound, and usually its not the entire cpu but rather a per core limitation which typically increasing IPC or performance per core will improve.
mumenrider
6 (0.01/day)
so i need to check number of threads in valorant okey
