CPU question
linktriscuit
44 (0.01/day)
Northern California
System Name N/A
Processor Intel C2Q Q6600 G0 @ default
Motherboard Gigabyte GA-P35-DS3L Rev.2.0
Cooling Zalman CNPS5X Cooler
Memory 2X 2GB Kingston HyperX PC8500 Memory Kit (KHX8500AD2K2/4GR)
Video Card(s) 512MB Gigabyte HD3870 GDDR4 (GV-RX387512H-B)
Storage WDC WD5000AAKX-001
Display(s) Dell 19" 1907FP LCD
Case Thermaltake M9
Audio Device(s) Onboard Realtek HD ALC888
Power Supply Antec Neo HE500 500W Modular
Software Windows 7 Home Premium 32-bit
Hello all, i was thinking of buying a new processor preferrably c2d, or quad core. I have my eyes set on either the e6600 or q6600. Any suggestions? Thanks for looking.
+1 on that if you got the cash. Thats a whole lot cheaper than you will probably get on that for a while. If you don't want to spring for the quad yet, get a 6750 as long as you have a board that can support high fsbs.
are you going to oc? instead of the e6600, look at the new e8400. q6600 is also a good choice. i have it. you could easily oc it to 3.0ghz with air cooling. too bad that q6700 deal ended the minute they put it up. but yeah. look between the e8400 and q6600. make sure the q6600 is G0 SLACR. clubit guarantee's it. G0 SLACR's runs less power which results in less heat. So if your planning to oc, you would be able to oc it further than you would if you didnt have G0 SLACR.
