Cpu temperature higher after changing thermal paste
zajegaga321
3 (0.01/day)
Hey, I'm very new to computers, but very interested. Today I replaced my CPU with new thermal paste (the first time since I bought this pc three years ago).
But I noticed that after replacing the new thermal paste, the cpu temperature became even higher, reaching 80-90 degrees when I run any game (previously 60-70), and in idle state it was a normal 40- 50 degrees (very strange??)
I searched, I used the"Aretic silver 5 thermal paste" made sure I was using the proper amount, tightened my water cooling fan (fan working fine), and even reapplied thermal paste twice, and the problem still persists. I can't think of any solution, I rellay don't want to purchase a new pc until next year. (still 15 :) ) I have attched a few images showing the temerature and the thermal past I applied. I hope someone can help me. This is really important for me, thank you so much.
9,340 (4.92/day)
Louisiana
Keyboard G710+x3
Try try again
Make sure your usb connection is on good this is how the pump gets power.
371 (0.38/day)
Arctic Silver 5 is a thermal paste that has a curing time. Until it is fully cured you could see higher temperatures. Curing time can be up to 200 hours. Apparently turning the PC off, letting it cool down and then restarting may help speed up the curing.
freeagent
10,403 (4.30/day)
Winnipeg, Canada
Cooling Thermalright Phantom Spirit 120 EVO, 2x T30
Memory 2x 16GB Lexar Ares @ 6400 28-36-36-68 1.55v
Display(s) LG 50UP7100
Case Asus ProArt PA602
Audio Device(s) JBL Bar 700
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
It doesnt.. I have played that game too many times :D
I would use a little less next time. Literally just enough to cover the IHS without being translucent.
196 (0.19/day)
Those temps are way off. So any explanation citing curing time feels bonkers very far fetched!
I think you literally screwed it up mate.
Take your time fastening the screws more evenly (switch around more with less screwing-in before moving on) in an x pattern.
And there are no bonus points for trying the thinnest covering possible. That´s not it at all!
If you want some neat trick simpy carry the tube of paste in your trousers until the paste warms up.
Even if you put 4 times too much on it: It makes for a far smoother and thinner plane of paste after getting pressed on than your manual attempts beforehand with cold paste will ever manage.
Good luck!
ps who didn´t try their fine motor skills out by trying to apply the thinnest layer of paste possible? We all did ;)
For the self-tap on the back, which is totally ok.
Simply don´t praise it as gospel to others afterwards :D
Toothless
Tech, Games, and TPU!
9,816 (2.42/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Maybe use something a bit more stable to watch temps, like HWinfo..
Ruru
S.T.A.R.S.
13,792 (3.05/day)
Jyväskylä, Finland
Cooling Eisbaer 360 + EK Vector TUF + Acool XT45 240mm + Swiftech res + EK-XTOP SPC-60 / Eisbaer 240 + DCC
Video Card(s) Asus RTX 3080 TUF / Powercolor RX 6700 XT
Display(s) 4K120 IPS + 4K60 IPS / 1080p projector @ 90"
Audio Device(s) Sony WH-CH720N / Hecate G1500
Power Supply EVGA G2 750W / Seasonic FX-750
VR HMD Oculus Rift CV1
AS5 was great 20 years ago, nowadays there are hella better selection of TIMs. Get a tube of MX-4 for example.
freeagent
10,403 (4.30/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Good luck!
:rolleyes: :rolleyes:
I think I would rather use AS5 :D
1,287 (0.74/day)
System Name Gamey #2 / #3
Processor Ryzen 7 5800X3D / Ryzen 7 5700X3D
Motherboard Asrock B450M P4 / MSi B450 ProVDH M
Cooling IDCool SE-226-XT / IDCool SE-224-XTS
Memory 32GB 3200 CL16 / 16GB 3200 CL16
Video Card(s) Red Dragon 6800 XT / Eagle 3070
Storage 4TB Team MP34 / 2TB WD SN570
Case Corsair 4000Air / TT Versa H18
Power Supply EVGA 650 G3 / EVGA BQ 500
LOL I was doing some toybox cleaning yesterday and found 2 tubes of Arctic Silver 5 to go along with 2 ID Cooling and an Arctic MX5 (yep, the big bad blue one). I should try the old Silver on the next pastejob just for fun.
zajegaga321
3 (0.01/day)
Good luck!
Thank you so much for the info, i will trey redo the a at screws today (should i re apply my paste? I already did that twice) ty
So would u say silver 5 is not working now? I bought the paste yesterday :(
Ruru
S.T.A.R.S.
13,792 (3.05/day)
Jyväskylä, Finland
I mean there are hella lot better TIMs than AS5. But it shouldn't still perform as shitty as it does for you :S
1,262 (0.21/day)
This sort of temperature difference is almost certainly to do with mounting, not some paste issue.
Re-mount and check again. Make sure your cooler's pump is running properly as well. Use something like HWInfo to monitor, not HWMonitor. HWMonitor is unreliable.
zajegaga321
3 (0.01/day)
Thanks, I will re do the whole thing again today and see it soon, thanks for all the advice:clap:
Hey thanks for all the help, just a quick update, this morning the idle tempertaure stayed around 30-40 degrees (yestorday was 40-50) don't know if it is due to morning is quite chilly, in the afternoon I will run the games and test agian (tired this morning valorant stayed around 70 ish) then redo the thermal paste process. :peace:
