CPU-Tweaker
839 (0.14/day)
System Name GB
Processor Core i7-4790K
Motherboard Gigabyte GA-Z97X-SOC Force
Cooling XSPC RayStorm D5 EX240 (Liquid Ultra)
Memory G.Skill F3-2933C12D-8GTXDG @ 3100 (CL.12) @ 1.66V
Video Card(s) Evga GTS 450SC
Storage 2xSSD Corsair Force GS 128 (RAID 0), WD Caviar Black 1TB
Case NZXT Phantom 630 Ultra Tower
Power Supply Gigabyte Superb 720W
Software Win 7 SP1 x64;Win 8 x64 (6.3)
CPU-Tweaker v:1.4 Final
http://www.tweakers.fr/download/CPU-Tweaker.zip
-Increase Reading Cas# on Intel Core i3 CPU.
-Interface was changed (the system information panel is more complete now).
-Add the change of core multiplier for Intel Core i3/i5 Clarckdale CPU.
-Improve the change of core multiplier for Intel Core i5/i7 Lynnfield CPU.
-Add support for Intel Core i3/i5 Clarckdale CPU.
-Fix the bug when aero is disabled if CPU-Tweaker is open on AMD CPU under Windows 7.
-Add some chipsets detection ID.
CPU-Tweaker v:1.5 beta2
-Add a window monitoring (Graphes CPU Load, CPU Temp, CPU & RAM frequency, Used RAM size).
-Add 2 systray Icons (CPU Load and Highest Temp).
are you the creator? just curious.
for some reason cpu-tweaker works good on my machine but after a few reboots i cant hit apply anymore. it gets grayed out.
CPU-Tweaker 1.5 Final
-Add a window monitoring.
-Replace the Average Temp graph by Highest Temp graph.
-Add a panel with time elapsed.
-Improve Reading Frequency on all CPUs.
-Fix Cas Latency reading with DDR3 on K10 CPUs.
I was wondering when they would make it support Sandy and Ivy cpu's. Thanks for posting this :)
been waiting for felix to update this app thanks stasio
Not reading VCore or VDimm.
