- Oct 6, 2009
- 2,831 (0.50/day)
- Midwest USA
System Name | My Gaming System |
Motherboard | Gigabyte b650 Aorus Elite AX |
Cooling | Phanteks Glacier One 360D30 |
Memory | G.Skill 64000 Mhz 32 Gb |
Video Card(s) | ASRock Phantom 7900XT OC |
Storage | 4 TB NVMe Total |
Case | Hyte y40 |
Power Supply | Corsair 850 Modular PSU |
Software | Windows 11 Home Premium |
Now this subject might have been covered before but I couldn't find an answer I was satisfied with in the Threads here so I am going to ask it anyways.
Alright I was tweaking my i5 750's @3.8 voltages and noticed something when looking in CPU-Z compared to the BIOS.
My voltages actually read higher in CPU-Z than in the BIOS.
Now I was under the impression that yes the voltages do usually read differently in CPU-z than in the BIOS. But I thought it was usually lower because of Vdroop. Well mine read higher.....
For instance I will show you.....
Vcore: 1.3 (In BIOS) = 1.28 to 1.31(in CPU-z)
DIMM: 1.63 (In BIOS) = 1.64 (In CPU-Z)
CPU VTT: 1.175 (IN BIOS) = 1.21 to 1.22 (In CPU-Z)
PCH: 1.10 (In BIOS) = 1.09 (In CPU-Z) <---bad example
CPU PLL: 1.875 (In BIOS) = 1.88 (In CPU-Z)
So with four out of the five showing higher voltages in CPU-Z than in the BIOS I wonder why it reads this way. So I tried reading it off of HW Monitor .... same thing. Next I tried Eleet (EVGA's Overclocking tool)..... same thing.
Like I said I thought the hole purpose for setting these values in the BIOS is so that they would not exceed the numbers you put it when spiking back after Vdroop.
Anyone shed some light on this???? I'm not really worried about it but I would still like to know why!
Thanks in advance guys!
