Create raster pattern in printable format for use with retro computing optical mouse
489 (0.29/day)
Belgium
System Name MSi Coffee Lake
Processor i7-8700k
Motherboard MSI Z370 GAMING PRO CARBON AC
Cooling NZXT something AIO loop
Memory 16GB Kingston HyperX 2133 C14 Fury Black
Video Card(s) TITAN Xp Jedi Order Edition
Storage Samsung 960 Evo NVMe
Display(s) Medion 23'
Case Cooler Master Stryker
Power Supply BeQuiet 600W
Mouse Logitech Trackman T-BB18
Keyboard Generic hp
I have an early serial optical mouse that uses a metal base plate with a raster pattern printed on it for the optical sensor to determine movement.
I have now found a service that can print personalized pictures on mousemats.
So I want to try out if i can replace the metal plate with such a mousemat.
For that, I need to recreate the raster pattern, but I don't have any graphical software.
What would be the easiest and quick way to create such a pattern?
Visiting a print lab, saying, "could you please draw this pattern for me?"
Or, if you're not into feeding printing companies you can download Paint.net (it's free) and see if you can draw it.
Are you ably to put up a pic of the mouse pad so we can see the type of pattern on it that way we could advise you better about how and what you could do to replicate it
It is just a fine square grid pattern.
The surface of the mouse pad is a bit larger than the metal plate, so just copying and zooming in or enlarging is not an option.
I am trying to count or measure the line density somehow (and will post a pic when able).
The printing service is just a hobbyist and used to mainly print travel pictures or portraits on mousepads and not very much tech oriented i might add.
I can not expect help in that sense. I expect that scaling will occur. I asked about some details of the printer to get the same line density on the mousepad.
<- this is what the pattern looks like upclose
It really is a simple repetitive pattern, like 3 black tiles and 1 reflective tile in a square configuration, and then repeat sideways and downward.
I can measure 3 patterns per mm. If a printer could print perfect square "dots" it would equate to 150 dpi.
