Creative Z Audio Stuttering Possible fix?...can I implement it?..
91 (0.02/day)
Aotearoa, the land of the thieving bees
System Name Enmitynz
Processor Ivy i5 3570k @ 4.6Ghz
Motherboard Asus P8Z77-V
Cooling Corsair H100
Memory 8GB Mushkin Frostbyte 1600mhz 9-9-9-24
Video Card(s) 2 x Sapphire 7970 Vapor-X 3GB in Crossfire
Storage 128GB OCZ Vertex 4 system drive,90GB Vertex 2, 1TB HDD, 3 320GB HDDs
Display(s) Samsung Syncmaster XL2370 1920x1080
Case Coolermaster Storm Stryker
Audio Device(s) Asus Xonar DGX + Sennheiser HD485's/Beats by dre Solos
Power Supply Corsair HX850V2
Software Win 7 Ultimate x64
Hey Guys, I've been having issues with my Creative SB Z stuttering when I have DTS or Dolby Digital enabled. It clicks and stutters like mad. However once I change my default audio device to SPDIF and then select "no encoder" from within the SB Software it works no problem (albeit, audio quality is much lower)
I've done a lot of research over the past few days uninstalling the official drivers, reinstalling them, updating the drivers, installing PAX drivers...none of this has helped my situation and the stuttering has continued when using DTS. Until I found this guy...
http://forums.creative.com/showthread.php?t=700567
and I think this might be the same person? but he fixed it!
http://forums.astrogaming.com/showthread.php?43059-My-Soundblaster-Z-A50-stuttering-problem-solved
This is the issue I am encountering, now...he changed his PCIE slot from 1x to 4x and it fixed his issue. I have a Asus P8Z77-V motherboard and due to running 2x 7970's I can only use the very top PCIE slot which according to reviews is only a 1x slot. Is there a way to change it to 4x?
If not...what else can I realistically try?
thanks for your help guys.
