Hi, i just realised that one of my 2 EAH 5770 isnt being used by the PC at all.
ran it on gpu-z and it shows 0 % load, fan speed at 30% and doesnt change even in game and even when the other card is at 80% and 70C.
Dont know how long this has been going on, got this pc a little over a year ago.
One thing i remember is loading speeds for BFBC2 suddenly doubled several months ago and i couldnt figure out why, though i remember now i did at some point install some new drivers (truth be told without really knowing what i was doing) to get some game to work. I think the 2 might be related.
Can anyone help?
GPU-Z says crossfire is enabled, although one card isnt used at all.
Can you tell me if uninstalling all drivers and reinstalling proper ones would fix the problem?
Ive also been getting extremely high temps (up to 100C this summer, fried a power supply)
this is a screen while having SC2 in background:
you can see all load is on primary, and CCC only displays 1 card in the drop down list
As you can see here GPU-z does detect crossifre running and both cards are in the dropdown menu:
this is a custom desktop and ill be contacting the builder soon to try and have this fixed, but if i can manage to fix it on my own it would be better.
thanks in advance for any help.
Can anyone help?
