Crysis 2 DX11/HighResTextures and 3-way CFX problem
32 (0.01/day)
South Korea
Hi. I just patched my Crysis 2 to v1.9 and got obtained DX11 / Ultra spec and High resolution textures. I tested newly-added options and compare them with late-highest setting, Extreme option. Here's the result.
My system is as follow:
CPU: Phenom II X6 @ 4.2GHz / NB 2.8GHz
Mainboard: MSI 890FXA-GD70
Memory: Samsung PC3-10600 4GB x 2 @ 1600MHz / CL7
VGA: Radeon HD 6970 2GB x 3 CFX
Storage: Intel SSD 510 Series 120GB
Power: CORSAIR AX1200 GOLD
First, I tested each graphic option under 3-way CFX configuration.
As you see, without any API or textures resolution change, changing spec from Extreme to Ultra brings about 14% performance loss.
Changing API from DX9 to DX11 cuts average framerate massively about -56%. DX11 in Crysis 2 seems that it's really hardware demanding.
Contrary to previous two tests and popular expectation, applying high resolution textures merely affects to performance - see and compare 'Ultra' and 'Ultra + HighRes', 'Ultra + DX11' and 'Ultra + DX11 + HighRes'.
Second is to test under various VGA configuration - single, 2-way and 3-way CFX.
There's something we missed at the first test: That is, CFX scale may decrease (or increase) by presence of newly-added options since there can be no suitable profiles for them in up-to current version of Catalyst.
It seems okay when we use single 6970 and even add another 6970. CFX scale for 2-way configuration is nearly 200% under both Extreme (DX9) and Ultra (DX11 + HighRes) settings. But adding a third 6970 is, though it shows nice 3-way CFX scale under late DX9 setting, almost meaningless for brand-new DX11 setting.
So, '-56% loss' at the first test is not made only by Extreme -> Ultra, DX9 -> DX11 change but also 'nullified' third VGA. We may expect that this massive DX11 performance loss under 3-way CFX can be moderated by future version of Catalyst or CAP (Catalyst 11.7 or 11.6 CAP2 perhaps).
So far, my points can be summarized as follows:
1. Changing from Extreme -> Ultra consumes framerate by around 14%
2. Under DX11 settings, as of today, third Radeon VGA worth nothing. (wait for coming Catalyst)
Thanks for reading :)
I m gonna upgrade soon lol the performance hit isnt that bad though :P but still i hope its playable for me :L
Hope my cf 6950's wil be able to play it at 1920x1080(I like to play FPS on my tv)
I'm playing Crysis 2 w/ high texture pack on and dx11 on w/ everything on ultra @ 1920x1080 w/ 2x 6870s and have yet to see it dip below 40 fps. Usually hovering around 60's.
So your 2x 6950s will just smoke it.
