- Jul 11, 2015
- 34 (0.01/day)
Processor | Intel Core i7 4770 (Haswell) @ 3.40GHz (Socket 1150 LGA) |
Motherboard | Gigabyte H87-D3H (1150 LGA) |
Memory | Corsair Vengeance 16GB DDR3 1600 |
Video Card(s) | NVIDIA GeForce GTX 780 Ti 3GB Windforce |
Storage | Samsung 840 EVO SSD 500GB, WD Green 6TB HDD |
Display(s) | LG 22" LCD (1920x1080 resolution) |
Case | CoolerMaster CM Storm Scout 2 Black |
Audio Device(s) | Creative Sound Blaster Z (PCIe) |
Power Supply | Thermaltake ToughPower 875W |
Software | Windows 10 Home 64-bit |
I cannot launch CS:GO under normal conditions. Every other game in my Steam library loads fine.
Each time I try to launch, I get an empty black screen. I can ONLY open the game if I use the "-safe" tag in launch options. I can alter the video settings and play full screen then with no problems after launching it in safe mode. But next time I launch it without the "-safe" tag, same blank screen happens.
I have tried searching high and low on the internet to find a remedy. I have posted on the official Steam website and had no luck. Cleared cache, deleted csgo.exe, reinstalled drivers and pretty much everything else you can imagine, bar reformatting the whole drive, which I am loathe to do because everything else works fine.
While the game is playable if I launch in "-safe" first, having to re input the video settings and change to full screen each time is an annoyance I would like to avoid.
Any suggestions?
Any suggestions?
