- Jul 9, 2016
- 1,090 (0.34/day)
System Name | Main System |
Processor | i9-10940x |
Motherboard | MSI X299 Xpower Gaming AC |
Cooling | Noctua NH-D15S + Second Fan |
Memory | G.Skill 64GB @3200MHz XMP |
Video Card(s) | ASUS Strix RTX 3090 24GB |
Storage | 2TB Samsung 970 EVO Plus; 2TB Corsair Force MP600; 2TB Samsung PM981a |
Display(s) | Dell U4320Q; LG 43MU79-B |
Case | Corsair A540 |
Audio Device(s) | Creative Lab SoundBlaster ZX-R |
Power Supply | EVGA G2 1300 |
Mouse | Logitech MK550 |
Keyboard | Corsair K95 Platinum XT Brown Switches |
Software | Windows 10 Pro |
Benchmark Scores | Cinebench R20 - 6910; FireStrike Ultra - 13241; TimeSpy Extreme - 10067; Port Royal - 13855 |
I am looking to either building a simple PC using spare parts vs buying the Netgate SG-3100. This is for home office and we are getting lots of DDOS attacks and I am having concern if my current router NETGEAR 4-Stream Wifi 6 Router (RAX15) can handle it well.
Custom PC parts, and I believe should be adequate -
Intel i7-3700S or 3770t, both can handle AES-NI
ASUS Rampage IV Gene Gen3 M-ATX
16GB DDR3
250GB SSD
Here is where I don't know how to start -
1. Do I need to buy an Intel NIC? I read and found Intel i350-T4 to be compatible. So do I plug in from the Comcast modem (WAN) to any one of the ports?
2. Do I connect one of the ports to my local LAN switch?
3. I need WiFI, so do I connect another port to my WiFi Router LAN port?
4. What is the correct way of doing this - should I enable DHCP and DNS from this machine and disable DHCP/DNS of my current Router, or should I continue to use DHCP/DNS of my current Router?
My concern is I have never used pfSense before, and I wonder how easy is it to install (via a bootable USB drive I believe?) and configure it, vs using the SG-3100 that has all the settings preset? And how long does it take to set up a very tight configuration? Any "preset" configuration that I can download?
Thanks in advance for any help or pointers.
16GB DDR3
250GB SSD
