PiePowerUP
- Dec 19, 2020
- 6 (0.00/day)
There exists a tool previously discussed here a few years ago. Thank you to NGOHQ. Intel Microcode Boot Loader Thread
The above link describes a method to load custom microcode after the bios but before memory initialization/kernel loading. This has a few different uses but the most common use is likely for older machines that never received bios level updates for CPU vulnerabilities via microcode updates.
The usage case of a somewhat more exciting utility would be optimizing performance on older systems that were particularly hit hard by Spectre/Meltdown and others, such as Sandy Bridge and Ivy Bridge. Other CPU generations such as Haswell can also benefit from this but it really does work for both AMD and Intel systems, regardless of the OS.
I'll defer to Win-Raid's own Killkernel: "...CPU Micro-code Rev. 1B for Ivy Bridge and 29 for Sandy Bridge may oblige you to increase the VCore of some step to maintain the level of stability achieved in an overclocked CPU with the older revisions that in this case are the Rev. 19 for Ivy Bridge and 28 for Sandy Bridge and for this reason in UBU is indicated "For Overclockers". Many overclockers claim they can maintain OC stability with less voltage when using these microcodes, using less power and producing less heat.
This can already be performed by means of editing or creating a custom bios for your motherboard that contains the desired CPU microcode but it cannot be swiftly swapped out for testing, benching, overclocking or for reasons of pure curiosity. That's where the USB stick method starts to shine! You can set it and forget it, or swap in different microcodes in the matter of 2 clicks or even remove the usb stick completely to return to stock behavior.
You might say "Great!" (or not, see below) So where's the hang up? The problem is that the Intel Boot Loader has a check in place that prevents the usage of older microcodes! Fine, if you're updating an old box that just needs vulnerability protection but no bueno for those who desire to choose which microcodes they wish to use.
For the inevitable number of folks who may look at this and didn't say "Great!" but maybe said:
"Why bother?" "Just leave it alone you'll never notice the difference." "Just use InSpectre." "Not needed, microcode updates have been slowly clawing back ALL lost performance with every update, just use the latest." (lol)
I submit to you the following: "What has your microcode done for you, lately?" All thanks to Travis Downs.
So where does that leave us? Unfortunately I do not possess the ability to work back through the Intel Boot Loader in attempt to disable the "newer microcode" check. The files needed are located HERE. Setup is easy, just extract the archive onto a fat32 usb stick and go.
Does anyone posses the necessary skills to dechiper enough python/find a solution to the microcode version check? Please discuss!
