DaVinci Resolve - how to create side-by-side output video?
636 (0.12/day)
System Name Smooth-Operator
Processor AMD Ryzen 7 3800x
Motherboard Asrock x570 Taichi
Cooling AMD Wraith Prism
Memory 2x16GB 3200MHz CL16@CL14 DDR4
Video Card(s) Sapphire Radeon RX 580 8GB NITRO+
Storage 2x4TB WD HGST 7K6 7200RPM 256MB
Display(s) Samsung S24E370DL 24" IPS Freesync 75Hz
Case Fractal Design Focus G Window Blue
Audio Device(s) Creative X-Fi Titanium PCIe x1
Power Supply Corsair HX850 80+ Platinum
Mouse Gigabyte Aorus M3
Keyboard Zalman ZM-K300M
Software Windows 10 x64 Enterprise/Ubuntu Budgie amd64
I was googling a bit about it and i was unable to find anything useful. Most of search results are about how to edit videos in side-by-side view but not how to render output video as side-by-side image. I would like to improve my youtube comparisons by creating sbs videos and i do not want to spend money on expensive software like vegas or adobe premiere for just one simple thing. Anyone here using resolve and knows how to do it?
I think you misunderstood my question and you gave an answer to question i didn't ask.
P.S.
I reported your post.
P.S.
Pretty sure he was showing you that you could save a ton of money for one simple thing, since the link is Vegas Pro 15 for $23-25!
Still, this answer is not related at all to question i asked. Davinci resolve is free for my needs and that's a software i want to use.
If i would ask "how to install a program on linux" and someone would answer "install windows" that would be the same kind of thing.
Pretty sure you are confused with your own situation here. You state that the software you have will not do what you want, and that you do not want to pay retail for Vegas or Premier. Another member comes in and offers a solution on the cheap and you report him for it and publicly try to slam him for his help. I then explain what happened, and you want to use an analogy to justify your stance, and in the end, we are trying to help you out. I still do not see the issue in what is being presented to you.
Click "Deliver" then "Star Render". Both will be rendered automatically.
Just tested.
