DD-WRT and Airport Extreme Base Station
freaksavior
To infinity ... and beyond!
8,095 (1.20/day)
System Name Server. Gamer. Worker.
Processor Xeon 2659 v3 / 9800x3D / m1 pro
Motherboard Asus X99-E-10G WS / ASRock steel legend x870 / Apple
Cooling Noctua low profile / Noctua NH-L12 / Apple
Memory 64Gb 2133 ecc ddr4/ T-force 6400 32Gbddr5/ 32GB HBLM
Video Card(s) Evga gt 7300 / zotac 3070 / m1 pro
Storage Samsung 970 512 Evo NVMe+3x14Tb /2Tb 990 pro + 1Tb HP 920 ex. / 1Tb
Display(s) Headless / Acer Predator X34 / Acer X34 Non predator
Case NZXT H630 |Rosewill 8bay 4u server chasiss / MacBook Pro 16”
Audio Device(s) Onboard / Onboard / Onboard
Power Supply Corsair TX750 / Corais ax860 | / Internal 250w
Mouse Headless / corsair m65 / g502 proteus core
How do i get this working? i've tried numerious times and i cant seem to get the dd-wrt to work with the airport.
Please no apple bashing if you dont have anything to say about my problem... like a solution. Dont reply.
anyway, anybody know how to fix this? i was reading its best to use wds but thats a of trouble and i dont wanna run wds
are you currently running any encryption? and what mode are you going for (bridge, repeater, client)?
I'm currently running tomato 1.23 on my WRT-54GL, and with some tweeking I have it attached to a Dlink RTR as a client for everything sitting in my entertainment center.
yes wpa2 and its dd-wrt v24. i want a wireless bridge to be setup.
I'm trying to think, it's late.... I know with newer RTRs they support 2 modes: AP and AP+WDS. If you want a true bridge to bridge where they only talk to each other you might end up having to get another RTR running dd-wrt or tomato.
I'm not that familiar with dd-wrt, but you might want to try running it as a wireless client using WPA2, see if there is an option to change it from a gateway to Router. you might have to setup a static route on each end so that way each router knows where to send the traffic from the Airport to the dd-wrt, and vice-versa.
on the other hand, WDS might support up to wpa now.
hmmm well im going to reconfigure it to be a switch so i should be ok.
