DDR 3 1600 has CL9 timings
D_o_S
954 (0.13/day)
Processor AMD Opteron 144
Motherboard DFI Lanparty nF4 SLI-DR Expert
Cooling Watercooled - Alphacool Nexxxos XP, BIX2, Eheim HPPS
Memory 2x 512MB OCZ PC 3200EL Platinum Rev.2 (TCCD)
Video Card(s) 2x Gainward GeForce 6800 Ultra (430/1200)
Storage 4x WD Raptor 740GD in RAID 0
Display(s) Eizo FlexScan L768
Case CM Stacker
Audio Device(s) Audigy 2
Power Supply Silverstone Zeus ST65ZF
There is one disturbing fact about DDR3. The timings will go bad but the speed of the memory will increase.
DDR3 800 memory will work at CAS latency 5 and 5-5-5 timings and as we all know DDR 2 can beat these settings as some good DDR 2 modules work at 3-4-4 timings and CAS Latency 3 (CL3). Well, that is not the worst latency you will see with DDR3. Some DDR3 800 modules will work at 6-6-6, CL6 timings but will probably end up cheaper.
DDR 3 1066 will start with CL7, 7-7-7 timings and DDR 2 at this speed works well at 5-5-5, CL 5 settings.
DDR3 1333 will work at CL8 with 8-8-8 settings while the fastest DDR 3 at 1600 will end up at 9-9-9, CL 9 settings. The good part is that all of these modules should work at 1.5 V.
We are sure that the companies such as OCZ and Corsair or similar ones will make these modules with even better settings and timings but these are the numbers to start with. CeBIT, the world's biggest IT tradeshow, will reveal a bunch of motherboards and DDR 3 memory modules.
Is the era of low-latency memory over for good?
210 (0.03/day)
hudson, fl.
Processor athlon64 x3800 oc'ed to 2.5 ghz
Motherboard ecs kn1-lite
Cooling ARCTIC COOLING Freezer 64 Pro
Memory 2 gig gigaram ddr 400
Video Card(s) geforce8600gt
Storage raptor 74k and 160 gig harddrive
Display(s) 19 inch lcd monitor with resolution of 1440x900
Case Antec case
Audio Device(s) sound blaster xi-fi
Power Supply 650 watts antec power supply
Software windows xp pro.
jezz, this could hurt the athlon 64 processors the most since the preform better with low latency.
702 (0.11/day)
Processor Intel Core i5 4690K
Motherboard AsRock Z97 Extreme4
Cooling Hyper 212 Evo
Memory 16GB
Video Card(s) R9 Nano
Storage 256GB SATA SSD 2TB WD Blue
Display(s) 1920x1080
Case Cooler Master Elite 130
Power Supply CX650M
Software Argh, Windows 10. I hated Windows 7. I hate Windows 10 more. Give me back XP!!!
ddr2 had high latency problems when it came out too
we just started to see CL3 ddr2 800 hit the market in the past few months
besides that the latency time is actually the same or less if you think about it
the speed doubles but the latency only goes from 5 to 9
so in the same 1 second span ddr3 is actually able to take more instruction than ddr2
WarEagleAU
Bird of Prey
10,812 (1.57/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
yeah I was thinking that too. Ive read numerous articles where balance is key. However, faster memory helps in everything. Lower latencies are nice for accessing stored info though.
4,994 (0.69/day)
South of England
System Name Box of Distraction
Processor Ryzen 7 1800X
Motherboard Crosshair VI Hero
Cooling Custom watercooling
Memory G.Skill TridentZ 2x8GB @ 3466MHz CL14 1T
Video Card(s) EVGA 1080Ti FE. WC'd & TDP limit increased to 360W.
Storage Samsung 960 Evo 500GB & WD Black 2TB storage drive.
Display(s) Asus ROG Swift PG278QR 27" 1440P 165hz Gsync
Case Phanteks Enthoo Pro M
Audio Device(s) Phillips Fidelio X2 headphones / basic Bose speakers
Power Supply EVGA Supernova 750W G3
Keyboard Cherry MX Board 6.0 (mx red switches)
Software Win 10 & Linux Mint
Benchmark Scores https://hwbot.org/user/infrared
It will be interesting to see how long it takes for the ddr3 to mature to the point where the latencies are acceptable again. As cartman said, ddr2 had latency problems from the start, but as it's matured it's doing as good or better than most ddr1 now. I can get 41ns out of my pc2-5300 kit.
The frequency vs timings for the new ram looks terrible though. High-end DDR2 can do more than 1200mhz these days, and at CL5 timings no less.
Wile E
Power User
24,318 (3.58/day)
System Name The ClusterF**k
Processor 980X @ 4Ghz
Video Card(s) Evga GTX 580
You also have to consider that these are rated at 800 at 1.5v and DDR2 is rated at the same speeds at 1.8v. Wonder what would happen if you pumped 2v thru them. It would basically be equivalent to puttiing 2.3v into DDR2, which isn't actually uncommon for top performing sticks. I don't think there will be much to worry about.
5,105 (0.74/day)
Sydney, Australia
System Name UltraPC
Processor E8500 Core 2 Duo, 1333Mhz FSB, 3.16Ghz @ 4.5GHz (got into Windows @ 4.75GHz)
Motherboard ASUS P5Q-e
Cooling CPU Cooler - TT V14 Pro, 2x120mm CM Blue LED fans, 1x90mm CM Blue LED fan
Memory G.Skill Pi 4GB (2x2GB) Dual Channel DDR2 PC8000 (1000MHz), 5-5-5-15
Video Card(s) Sapphire HD4850 512mb with ASUS EAH4850 BIOS
Storage 2x 500GB Seagate 7200.12 Raid 0
Display(s) Acer AL1912, 19" LCD screen
Case Thermaltake Soprano Black ATX case
Audio Device(s) Onboard 7.1, Speakers - 5 + Sub + Monitor speakers
Power Supply Thermaltake 850W Toughpower Cable Management - Quad (2x18A and 2x30A) 12V rails
Software Win 7 Pro x64, MSN, CS:Source, etc etc
Super high clocks FTW :D
