DDR3-2000 (9-10-10-24-1T)
BePolite
15 (0.00/day)
I managed to get some very cheap Samsung 'green RAM' back in the day for about €30 second hand. This was a great price for 16GB 2 years ago here on the emerald isle. It over clocks well at 1.65v but the sweet spot I am finding is 2000 as opposed to 1866 or 2133.
My question is: is there any reason not to run it at 2000, it seems when you search that frequency almost never comes up.
I'm running a 3570K @ 4.4Ghz on a Z77 Sabertooth.
Many Thanks.
FreedomEclipse
~Technological Technocrat~
24,796 (3.77/day)
(currently) Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
If it can handle the speed then i dont see why not
BePolite
15 (0.00/day)
Many Thanks! I just wondered if there was some odd timing issue at 2000. I suppose that would be documented if there where. Thanks for your reply :)
Aquinus
Resident Wat-man
13,199 (2.73/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Software MacOS 15.3.1
Well, from a performance standpoint there isn't much reason to overclock the memory. 1600 is more than enough for your CPU. Granted I'm not one to talk considering my memory is stock at 2133 and it's running at 2400, but I don't really see any performance improvement from it.
How are you achieving 2000Mhz? I personally don't have a divider to hit 2000Mhz without adjusting the bclk strap to 125Mhz, which you can't do with your CPU.
FreedomEclipse
24,796 (3.77/day)
nope, some games and apps like the extra bandwidth/speed that comes with faster ram. also $30 is a lot better then buying 2133mhz at todays inflated prices, the price has doubled if not tripled
BePolite
15 (0.00/day)
The Z77 Sabertooth just has the divider, oddly. My bclk is the standard 100Mhz, to be fair this is what got me thinking 2000 might be some sort of odd speed with it's own drawbacks.
Funnily enough memtest reports it as 2666 so again something made me wonder. CPUZ reports it correctly in Windows.
1,317 (0.30/day)
System Name Gamer/ HTPC
Processor AMD Ryzen 5 2600
Motherboard ROG Crosshair VI
Cooling Alphacool Eisbaer 420 AIO
Memory G.Skill TridentZ RGB 2x8GB 3333 CL14
Video Card(s) Gigabyte Aorus RX 580
Storage Corsair Neutron 480 GB
Display(s) Samsung 42" 1080p
Case Phanteks Enthoo Luxe Tempered Glass
Power Supply Corsair 750
Software Win10 Pro
Benchmark Scores http://hwbot.org/user/johan45/
Best way to find out your performance gain/loss is with Aida64
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
Exactly. It's a dance between CAS and speed. Look at some of the older DDR3 memory reviews by Darksaber, he published charts with plenty of different CAS and Speed timing mixes.
BePolite
15 (0.00/day)
This is how I arrived at 2000 tbh - at 1866 I couldn't quite squeeze CL 8 out of it so I bumped up to 2000 with CL9. Seems there is no issue with 2000 per se so given the benches I'm getting and memtest runs 24 hours with no errors I think I'm good.
Thanks again to everyone who posted this forums is so helpful!!!
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
Sounds like it! Prime95 also is a good sideline memory test if you're so inclined. I tried getting 2400 out of my sticks and couldn't even do CL12. Since they work flawlessly at the advertised profile 2133 C9 1.65v, I'm happy with them.
cadaveca
My name is Dave
17,238 (2.48/day)
I did too, until all the ICs were on the market. Once we knew what was out there, there wasn't much point in providing such info any more. ;) OEMs had already started binning everything tightly.
Samsung LP/LV sticks got that testing though:
http://www.techpowerup.com/reviews/Samsung/MV-3V4G3/7.html
I'll do it again for DDR4, too. I'm actually pretty eager to see how it works at launch, gonna be pretty interesting.
I say go for 9-11-10-27 @ 1.5V 2133 MHz with these sticks as optimum. I can list some timings for your board if you post up BIOS screenshots, too, BePolite.
2,695 (0.41/day)
System Name panda
Processor 6700k
Motherboard sabertooth s
Cooling raystorm block<black ice stealth 240 rad<ek dcc 18w 140 xres
Memory 32gb ripjaw v
Video Card(s) 290x gamer<ntzx g10<antec 920
Storage 950 pro 250gb boot 850 evo pr0n
Display(s) QX2710LED@110hz lg 27ud68p
Case 540 Air
Audio Device(s) nope
Power Supply 750w superflower
Mouse g502
Keyboard shine 3 with grey, black and red caps
Software win 10
Benchmark Scores http://hwbot.org/user/marsey99/
i have some corsair sticks that love 2000mhz too, cas 7 on 1.7vdimm :D
anything 1166 or later hates them :cry:
MyNewRig
13 (0.00/day)
There is performance gains from faster RAM in apps that are CPU bound and in many games, although i admit that there are diminishing returns, i see some games improve their minimum FPS very significantly with faster RAMs ..
For example i have been benching Thief Master Thief Edition, and on 1333Mhz the minimum FPS was 29.6FPS on 2400Mhz it was 34.1FPS ... on 2133Mhz it goes up to 38FPS
average FPS remain almost the same with like 1FPS difference between fastest and slowest frequencies, Max FPS gain like 2FPS from faster RAM ..
The increase in the minimum FPS means smoother game-play, i have seen another thread few months ago of a guy who done massive tests as well and he established that although average FPS remain almost unchanged, minimum FPS does improve a lot with faster RAM.
this title is not CPU bound but it does use the CPU extensively, i have other CPU bound apps that show a lot of difference, system boot times improves a lot with faster RAM, overall responsiveness when multi-tasking improves ..
Like discussed with cadaveca in another thread, 2133Mhz CL9 seems to be the sweet spot, above that sometimes you get worse results ..
7,111 (1.00/day)
USA
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
Pretty good deal there ^ Ive found that as a rough guess, increasing ram speed from 1600 to 2133 usually seems about the same as +100 mhz cpu clock.
OP: I have 5 sticks of green. Might pick up a 6th to match the set, you can find it on ebay mislabeled sometimes, just make sure not to get the ECC version.
I have found they all perform identically and consistently, usually 1.5v even to get 2133 11-11-11-33 1t lazy overclock. I never dialed them in any tighter due to laziness. Sadly they run horribly on my Gigabyte Z77X-UD3H main rig, despite trying custom bioses etc. Did you adjust your secondary and tertiary timings? I would be interested to know the full timings you run so I can duplicate on itx. Was 1.65v necessary?
BePolite
15 (0.00/day)
I think I've misled people sorry - this is green RAM by virtue of colour rather than the 'green' stuff floating about. It's a different part number I think:
M378B5273DH0-CH9 is what I have.
Sorry.
cadaveca
My name is Dave
17,238 (2.48/day)
Sorry.
No apology necessary. Same stuff.
Well, earlier version of the same stuff. Most users are familiar with HYK0, while you have HCH9. The ICs are slightly different, but general behavior is very close to other Samsung-made ICs.
