Hi guys
Got z77-a , F3-12800CL9D-8GBXL (dual rank) , and i5 2500
Testmem5 anta777 and 1usmus_v3 find no error with both sticks when they installed solo , but when I try both sticks w dual channel 1usmus_v3 always find +15 error even at 800 mhz
Can it be cpu dont support 2x dual rank ? If so will 2500k might support?
Does testmem5 ok with ddr3?
I tried setting vcore to pretty high too
Tried another mobo p8b75 , same thing
Found similar: https://www.techpowerup.com/forums/...e-bsod-but-single-ram-is-running-fine.167856/
" The broken stick works fine on its own since the strain put on the memory bus is lower with only one stick, but with more RAM installed the workload increases and the faulty stick can't handle it "
