- Dec 16, 2018
- 19 (0.01/day)
System Name | Computor! |
Processor | Phenom II 1100t black edition |
Motherboard | GA-970A-D3 |
Cooling | Defualt Case Air; PCI fan blower, some HDD fans. |
Memory | (2x4GB) DDR3 PC3-16000 9-11-9-27 Blackline (996991); Black Mamba (2 x 4GB) 1600MHz (PV38G160C9K) |
Video Card(s) | PNY 1060 3gb xlr8 |
Storage | 250gb ssd, 750gb easy raid 10 |
Display(s) | Asus VK278Q Black 27" 1920x1080 2ms Full? HD HDMI LED BackLight LCD 300 cd/m2 10,000,000 :1 (ASCR) |
Case | Aspire/Apevia? X-Superalien case(blue) |
Power Supply | Corsair TX650W |
Mouse | Logitech G402 |
Keyboard | Emachines generic keyboard |
Software | Fedora 28 |
Benchmark Scores | Unigine: heaven: 1300ish(custom), 1611(Extreme); Valley: 1864(ExtremeHD) |
This is my mobos memory timing selection once you hit manual:
I'm currently at: @1600mhz
1T/2T Command Timing
Options are: Auto (default), 1T, 2T.
CAS# latency
Options are: Auto (default), 5T~14T.
RAS to CAS R/W Delay
Options are: Auto (default), 2T~19T.
Row Precharge Time
Minimum RAS Active Time
Options are: Auto (default), 8T~40T.
TwTr Command Delay
Options are: Auto (default), 4T~9T.
Trfc1 for DIMM1, DIMM3
Options are: Auto (default), 90ns, 110ns, 160ns, 300ns, 350ns.
Trfc0 for DIMM2, DIMM4
Write Recovery Time
Options are: Auto (default), 5T~8T, 10T, 12T, 14T, 16T.
Precharge Time
Options are: Auto (default), 4T~10T.
Row Cycle Time
Options are: Auto (default), 10T~56T.
RAS to RAS Delay
Options are: Auto (default), 1T~9T. (Note: This is only 4-9 or 10 I think in the actual bios)
**DCTs Drive Strength**
ProcOdt(ohms)
Options are: Auto (default), 240 ohms, 120 ohms, 80 ohms, 60 ohms.
DQS Drive Strength
Options are: Auto (default), 0.75x, 1.0x, 1.25x, 1.5x.
Data Drive Strength
MEMCLK Drive Strength
Addr/Cmd Drive Strength
Options are: Auto (default), 1.0x, 1.25x, 1.5x, 2.0x.
CS/ODT Drive Strength
CKE Drive Strength
**DCTs Addr/Cmd Timing**
Addr/Cmd Setup Time
Options are: Auto (default), 1/2T, 1T.
Addr/Cmd Fine Delay
Options are: Auto (default), 0/64~31/64.
CS/ODT Setup Time
CS/ODT Fine Delay
CKE Setup Time
CKE Fine Delay
Channel Interleaving
Enables or disables memory channel interleaving. Enabled allows the system to simultaneously access
different channels of the memory to increase memory performance and stability. (Default: Enabled)
Bank Interleaving
Enables or disables memory bank interleaving. Enabled allows the system to simultaneously access dif-
ferent banks of the memory to increase memory performance and stability. (Default: Enabled)
DQS Training Control
Enables or disables memory DQS training each time the system restarts. (Default: Skip DQS)
CKE Power Down Mode
Determines whether to set the memory to power down mode when the CKE pin is closed. (Default: Dis-
abled)
Memclock tri-stating
Determines whether to enable memory clock tri-stating in CPU C3 or Alt VID mode. (Default: Disabled)
1T - 1T/2T Command Timing
9T - CAS# latency (just dropped to 8 without memtester errors. I'll do memtest64 run later to double check.)
9T - RAS to CAS R/W Delay
9T - Row Precharge Time
18T - Minimum RAS Active Time (just lowered to 15T)
4T - TwTr Command Delay.
8T - Write Recovery Time (just lowered to 5T)
4T - Precharge Time
33T - Row Cycle Time (Might be able to push 32, but will likely get errors.)
4T - RAS to RAS Delay (Doesn't go below 4T despite what the manual says.)
Everything else is default
I can't seem to get the Cas# Latency or other 9 values down farther. Although I haven't tried much with the other two.
Minimum ras active time I might be able to lower more.
Row Cycle time might be able to get to 32 but no lower and likely unstable.
Write Recovery time I think I can get down to 4.
is it worth doing the other numbers? Are there tricks or things you can't or should get down or values you should keep at certain ratio to other values? What can I do to improve this?
