- Jul 15, 2019
- 626 (0.30/day)
- Hungary
System Name | MU-TH-UR 6000 |
Processor | AMD Ryzen 9800X3D ECO mode |
Motherboard | Asrock B650 PG Lightning |
Cooling | Corsair H100 AIO AM2+ |
Memory | 4x16GB Puskill DDR5 6400@6000 CAS32 |
Video Card(s) | Sapphire RX7900XT 20GB Nitro+ undervolted |
Storage | Samsung PM9A1 1Tb + 2x PM981 512Gb + Kingston HyperX 480Gb + Samsung Evo 860 500Gb |
Display(s) | HP ZR30W (30" 2560x1600 10 bit) |
Case | Chieftec GX-01B-OP Alien style |
Audio Device(s) | Genius Cavimanus |
Power Supply | Super Flower Leadex 750w Platinum |
Mouse | Logitech G400 |
Keyboard | IBM Model M122 (boltmod, micro pro usbc) |
Software | Windows 11 Pro x64 |
I have to sell my Samsung B die kits. (4x8gb patriot blackout 4133@4000 cl15) because i need more ram, there are projects that require more than 32gb. And i don't want to buy another expensive kits. (i need at least 64gb)
So i decided to use cheap ECC REG dimms, i modded my bios to the older microcode that supports ecc reg. I can sell the patriot dimms at a good price.
I have a lot of ecc reg dimms in my other workstations, so it is much better to use it than unbuffered dimms.
First i have to test 4x16gb Samsung m393a2g40eb1-cpb (2Rx4 2133) Samsung E-die dimms. I tested it and runs fine at 3200mhz (default cl22 timings), i think it maxed out at 3400-3600 or maybe at 4000?. (there is a few youtube reviews for samsung e die)
But i also have 6x16gb Hynix Dimms hma82gr7djr4n-xn (1Rx4 3200mhz ) Hynix D die (DJR?) die dimms. not yet tested.
Samsung modules are dual rank, hynx are single.
The goal will be 8x16gb modules so i think i need another 4x samsung or 2x hynix modules but these are cheap (~15 usd each 16gb dimms, the b die 8gb dimms was 35usd each)
But I will try to see if the 4+4 mixed module works. (but i dont think i can mix different rank modules)
For cooling i got two 8cm silent arctic p8 fans over the dimms.
So which modules should I use and start overclocking?
