dead Gateway GT5032
gt5032
1 (0.00/day)
OK, I have one of the hundreds of dead Gateway's that use the Foxconn C51GU01 MB. I am also seeing some of the GT and other series that use the FIC KTB51G on Ebay with the same condition, no POST, video, or keyboard, only harddrive and fans work. I have read that maybe FIC made the boards for Foxconn. I contacted Foxconn, they said "we supply the board but don't support it". The 2 boards look the same so who knows?
I have my board out, can see no popped capacitors or burned area. Had the power supply tested, they told me it was ok. reset the BIOS and unplugged everything plus all the other tips I have read in the last 3 months. still same results.
questions:
is there any tie to the famous emachine power supply troubles? this has a bestec 300w.
what is the actual failure on these boards?
if both boards are failing, what makes the board fail? is it another part or even the case?
does any body repair them?
can I make my Gateway supplied W-XP work with a new board that is not an exact replacement? if so, how do I do that?
Gateway must know this is a problem board, but they simply don't care. I have been reading other forums that suggest this is a widespread problem.
thanks in advance for any advice.
