- Jan 19, 2017
- 452 (0.15/day)
System Name | Core p90 |
Processor | I7 9700k |
Motherboard | ASRock Z390 Phantom Gaming 4 |
Cooling | Ek supremacy evo cpu block/nexxxos ut60 rad 480mm/D5 vario pump 310mm reservoir combo. |
Memory | Trident gskill 4x8gb 3000mhz (temporarily running 2x 32gb ddr4 corsair vengeance 3600mhz) |
Video Card(s) | Nvidia Founders edition rtx 3080 10gb |
Storage | M.2 Intel 660p 1024gb, 4tb 7200 rpm black Western Digital hdd |
Display(s) | Acer x34 predator 3440x1440p 120hz g-sync ultrawide 21:9 monitor |
Case | Thermaltake Core P90 tempered glass edition |
Audio Device(s) | On board |
Power Supply | Thermaltake smart m1200w |
Mouse | Razer Basilisk v3 |
Keyboard | Logitech G910 |
Software | Windows 10 64bit |
Is it necessary to deburr/sand petg tubes?
What do you use? I've got a bitspower tool that cuts and deburrs tubes but it makes a mess of the petg and it seems to be deburring the inside and not the OUTSIDE
In my case, I'm using petg with friction fittings (bitspower enhanced multi link) the damage to the O ring could only be done if the outer edge of the tube was irregular or too sharp.
And my other question:
About inserts. I've read on the Web that its best not to out water on them because it will expand when I use the heat gun. Is that true?
Also I find that fitting the tubes inside the fittings when my tube run is done proves to be difficult, I often have to press hard to try different angled. Is there something I can do to make it pop in easier?
Such as using water or soap?
