Dedicated PSU for GPU
1,510 (0.37/day)
Processor 11900K
Motherboard ASRock Z590 OC Formula
Cooling Noctua NH-D15 using 2x140mm 3000RPM industrial Noctuas
Memory G. Skill Trident Z 2x16GB 3600MHz
Video Card(s) eVGA RTX 3090 FTW3
Storage 2TB Crucial P5 Plus
Display(s) 1st: LG GR83Q-B 1440p 27in 240Hz / 2nd: Lenovo y27g 1080p 27in 144Hz
Case Lian Li Lancool MESH II RGB (I removed the RGB)
Power Supply Seasonic Prime 850 TX
Mouse Glorious Model D
Keyboard Glorious MMK2 65% Lynx MX switches
Software Win10 Pro
So I've been having power spike crashes I believe. I can stress the GPU hard and get a full system crash. This didn't really start happening until I swapped my old PSU into another system and used my Seasonic TX 850W, which is crashing.
My solution I was going to try was use a 2nd PSU I have but dedicate it to my GPU to try and rule out power problems.
The question about this is I can just lay that PSU on top or inside the case anywhere right? And for the powering on procedure wouldn't I want to start in a certain order?
So with everything off I should 1st switch ON the dedicated PSU for the GPU and then 2nd is flip the switch on the motherboard's PSU to ON. 3rd is start the PC.
Shutdown is just reverse order right?
I'm pretty sure that's how I used to do it with mining rigs but it's been a while and I wanted some clarification. No I won't be syncing the PSUs.
you can just spend 4-7$ for one of those ATX splitter cables (sometimes they sold named under Dual-PSU ATX adapter)
another way is to spend 7 - 12 $ to buy one of those DualPSU circuits/boards
so both of your PSUs will kick at same time.
I'm attaching both of their photos for refrence
Are you on a 3060?
Have you tried it in another system?
It might be failing, and not your psu.
Are you on a 3060?
No it's a 3090. My system specs may need to be updated on TPU. Didn't used to do this until I swapped PSUs. Pretty sure the card is fine, I can repeat the crash and alleviate it by managing the power consumption of the card.
I've powered just the GPU(s) with different PSUs .Either get the dual 24pin thing that makes it so the second one turns on with the first. Or the old fashion way. Jump green and black pins with a paperclip (or use a official thing). Make sure it's turned on and running before turning on the computer side the GPu needs to be detected during boot.
I may have run a 2nd PSU for a few months because I was lazy and didn't want to swap out the case on before :)
Iirc there is an adapter that allows both to start up at the same time
I have one of those, came with my Stacker.
I dunno man... there was a time when I would have run dual PSU's.. but I think I would rather just roll with one solid one.
But.. you cant always get what you want, so what you need is the adapter, or a paperclip :D
Adapter
yeah, they aren't expensive and they work.
Kinda sounds like you just need a new power supply though. Even with a 3090, that 850w should be fine. If it's not enough, you are running some wild stuff.
You can lick it. No arcing :)
Yeah, the green wire only for power on there won't be any arching of high current. I done this many moons ago, it's totally safe.
Adapter
It's just power spikes that do it I'm pretty sure. Doesn't seem to handle it as well.
When I had a mining rig going I was on 220v with my current PSU, the 850 TX, running the mobo and a few cards while a server grade 2200w or 2400w took care of the rest of the cards.
I'm pretty dang sure I didn't use any clips or jumpers or adapters like that. As long as I had the server supply on first so those gpus would power on and be detectable.
Now what you guys are probably right about is a secondary ATX supply isn't going to just power up a card like a server PSU did. So I think that 850TX came with an adapter too. The secondary supply would be an eVga 850 G2. I'll have to dig out the box.
Maybe that server PSU was always-on type? I've dealt with that in industrial stuff. Once it gets power, all lines are hot.
Really haven't heard of any ATX PSU turning on by itself. Needs some feedback on / voltage request. Power is dumb, not smart.
Remember these? I bet that similar but modern and beefier ones would actually be somewhat popular if modern cases had 5.25" bays.
Before you do it think about GND. (i talk about the wiring / and not all the details i hint out)
The server psu had a breakout board for connections and control. It was just ON/OFF there was no detection that I remember.
Using an adapter or paperclip would just essential be my controls from the old server style setup.
Having the adapter always plugged into the secondary PSU should just fire the GPU up right away upon flipping the switch on the PSU, right? Turning the card on or off should just be the switch on the PSU?
Think about the grounding wire? Is that what you mean?
I have, it's probably not correct honestly, the house is older, I think a few too many corners cut. The surge protector says it's not grounded, though it doesn't always show that so I don't know why exactly it shows that sometimes grounded and sometimes not.
If the secondary PSU doesn't fix it I was going to just run a new breaker to this side of house. Needs it anyways but I just need a real reason to do it, maybe it's finally the one reason that's going to make me do it?
The adapter should immediately power the 2nd psu up
After trying a dedicated 2nd Psu, my shutdown problem is gone.
I've updated my system specs for anyone curious, an 11900K, RTX 3090 and Seasonic 850 TX.
There were several of the seasonic supplies (among others) that could not handle the spikes from a 3090 when they came out. Back then, Seasonic was one of the brands offering replacements in that situation. Most of the companies came out with new power supply versions after that so they could handle the spikes.
iirc, those seasonic 850 units are designed to handle 1100+w spikes.
closer to 1200 actually
from the review
the PSU doesn't have any problems under almost 1.2kW of load (at normal ambient temperatures, at least)
I bought a Superflower Leadex SE 1200w and shutdowns have been alleviated.
I was granted an RMA from Seasonic.
Still need to ship it to seasonic. Will try to do that this week.
Do Superflowers still have those rad looking LED connectors ?
I am being offered a Vertex PX 1000 ATX 3.0 unit for RMA.
This is step down in efficency and model series, but 1 step up in power provided.
Is this seem adequate for replacement? They said my unit was out of stock and discontinued.
Demand the noctua supply? /s
It honestly seems like a fine replacement to me considering the smallest prime unit they make now is a Titanium 1300w.
