Deepcool DA600w plus bronce rx6700xt. Help
Status
Not open for further replies.
nhauel2k
5 (0.01/day)
Hello, I have a deepcool DA600w 80 plus bronze power supply. I would like to know if it is a very good source to power an AMD RX6700xt graphics card?? Or which one would you recommend? I have a Ryzen 5 5600G processor.
Most of the info I can find on Deepcool's non-modular DA series is on the 500W model, but it appears the product line is based on CWT's GPT platform, so at least it would be made by a reputable OEM. I'd expect it to work okay. It has the usual cut corners on a cheap PSU like cheap capacitors and a sleeve bearing fan, but it shouldn't immediately blow up on you.
Here's a link to Cybenetics' tests of two DA500 samples.
One thread on your topic is sufficient, otherwise getting help will be difficult with members replying across 4 threads so this one is closed.
Status
