Deepcool Rolls Out GAMMAXX GTE V2 White CPU Cooler
47,692 (7.42/day)
To help with your snow-themed builds on a budget, Deepcool rolled out a [mostly] white variant of its GAMMAXX GTE V2 tower-type CPU cooler. The GTE V2 White features a silvery-white top-plate that caps the aluminium fin-stack heatsink; white caps for the heat-pipes, while fan-frame and impeller, and a white LED illumination for the fan. The aluminium fins retain their typical chrome finish.
The GAMMAXX GTE V2 features a tower-type aluminium fin-stack heatsink to which heat is conveyed by four 6 mm-thick copper heat pipes that make direct contact with the CPU at the base. The included 120 mm fan takes in 4-pin PWM input, spins between 500 to 1,650 RPM, pushing up to 64.5 CFM of air, with a maximum noise output of 27.8 dBA. The fan features a hydro bearing. Measuring 129 mm x 77 mm x 157.5 mm (WxDxH), including fan, the cooler weighs 650 g. Among the CPU socket types supported are AM4 and LGA115x. Expect the cooler to be priced at a tiny premium over the USD $30 price of the standard model.
That things a beast.
Legendary Lineage.
Enthusiast: Now we'll see who the real culprit is. *reveals face* It's 212!
212: I would of gotten away with it if it wasn't for those peaky enthusiasts.
Its made in the coolermaster factory.
$30? Just go on aliexpress and search for snowman cpu cooler. Then spend some coin on a white fan and you'll probably still be saving yourself at least $10 or more
If this is a "WHITE" cooler, then why do I still see silver aluminum on the fin stacks and copper-colored on the heat pipes (not talking about the part that contacts the cpu) ????
Granted, it is closer than most of the other so-called "white" coolers that have come out lately, but as the saying goes: "close only counts in Horseshoes & Hand Grenades" ...:laugh:..:eek:..:fear:
Therefore, I say: f.A.I.L......again !
I got a snowman, but it melted:roll:
Actually a great and CHEAP cooler
Sadly that one is not compitable with AM4. :(
They provide a bracket kit
So they do provide AM4 kit.
Just get a white enermax cooler. Pure white.
The Snowman is currently going for $18.24 U.S. (with a new-user coupon good for another $3 off) and has two PWM fans.
If you have to have a white fan, this single-fan model costs $1.37 less.
Theyve also got a 6 heatpipe version for the same price - they call it the T6. Another $13 on a white PWM fan
That looks damn nice
if I painted my Sunbeam 120 .....
