"Delayed Write Failed"
zonc
10 (0.00/day)
Hi
I was running my system on Samsung HD250HJ drive, pretty much fine (some problems with going into PIO mode but been OK for a while) but recently I bought Samsung F1 500gb HD500IJ and have this issue from beginning. It looks like this: I start copying files from this 250gb drive, it keeps going fore some time but at some moment i get a pop-up message in the right bottom corner which says "delayed write failed, some data may be lost or damaged..." etc. then my PC goes "slow-mo" when i try to acces files on that 500gb drive or any programs running from that disk. After i reboot, these files which failed can be copyied now, and it keeps going for some time until i get next "delayed write failed" again, and again.
From what i searched the web this is pretty much a common issue on WinXP, especially with external drives (this one is not one ofcourse). What i tried so far:
- added "IoPageLockLimit" at registry/memory management
- changed "system pages" to a value of "FFFFFFFF"
- disabled write caching on that drive,
but none of them helped. I ran out of ideas, and this whole thing is annoying when i get this like 3 times a day. Some more info:
- WinXP installed fine on that disk without problems
- happens with both small and large files
- SMART reports "B8 attribute" to be FAILED, but this is common issue AFAIK with F1's
- no bad sectors, all fields are green
- got 4 partitions on 250gb and 4 on 500gb drive (8 total), all are NTFS
- Gigabyte 965-DS3 mobo (no AHCI), 3gb RAM, ATI 4850 video
- SATA cables not bend, temperatures normal
THX for any help and sorry for ma bad english :)
Solaris17
Super Dainty Moderator
27,610 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
Video Card(s) MSI SUPRIM Liquid 5090
Audio Device(s) Moondrop S8's on chitt Gunnr
Keyboard Wooting 80 HE White, Gateron Jades
VR HMD Quest 3
Hmm this happened to me alot in XP as well i would try updating every driver you possibly can including chipset...thats all i can reccomend i never figured out how to fix it i just ended up switching to vista..
557 (0.09/day)
Bradford, PA
System Name Fenix
Processor AMD A8-3820 @ 3.1GHz
Motherboard HP 2ACF
Cooling AMD
Memory 8GB DDR3 @ 9-9-9-24
Video Card(s) AMD Radeon HD6550
Storage 320GB Seagate
Display(s) Dell 19"
Case Unknown
Power Supply Corsair TX650W
Software Windows 7 Home Premium
Could be the hard drive. When did you buy it? Maybe you could try to RMA it.
Good luck man!
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
I've seen that a few times with:
  • Overclocked PCI (hard drives on that bus)
  • Hard drive going bad
10,885 (1.54/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
Evil person you... suggesting Vista!!! Hahahahahahaaaa!!! :laugh:
Solaris17
27,610 (3.84/day)
Alabama
VR HMD Quest 3
I dont suggest at least with XP it didnt think my SATA HDD's were removable devices..that pisses me off when i go to remove my thumb drive and all of a sudden half my desktop icons dissapear.....i was just saying what fixed it for me..though if he updates his chipset drivers and does a checkdsk on his drive he can probably fix it :)
zonc
10 (0.00/day)
Little update:
I checked that "write buffer" on both disks and somehow it was DISBALED on 250gb drive and ENABLED on 500gb drive, while it should be opposite. Maybe i switched it wrong? anyway this seems helping right now (now errors for like 1,5 hour now). I'll keep you posted!
Oh and PCI-E is blocked at 100MHz, otherwise overclock fails (cpu got only x7 multiplier so fsb needs a lot of MHz)
CarolinaKSU
442 (0.07/day)
System Name ANTC-1221
Processor Intel Core2 Quad - Q9550 2.8ghz
Motherboard ASUS P5Q-Deluxe
Cooling Xigmatek HDT-1283
Memory G.SKILL 4GB (2x2GB) DDR2-1100 1.8v
Video Card(s) EVGA GTX 280
Storage 2x Samsung Spinpoint F1 HD753LJ 750GB in RAID0, WD Caviar 500GB
Display(s) Hanns-G HW223D 22"
Case Antec 1200
Audio Device(s) HT Omega Striker connected to Logitech G15 5.1 Surround
Power Supply Thermaltake Toughpower W0116RU 750W
Software Vista Home Premium 64-bit
I saw this all the time with my old Seagate 250gb HDD in an enclosure using Firewire to connect them. For the longest time I thought it was the controller within the enclosure itself messing up, turns out that that particular model of hard drive just did NOT like being used with firewire. Works great (3 RMA'd enclosures later from Tiger Direct, thanks Ultra and your crappy plastic rubbish enclosures!) with USB now though. Weird.
B-Rock
1 (0.00/day)
Processor AMD Athlon 64bit 3500+
Motherboard ASUS A8N-E
Cooling Standard
Memory 3GB Kingston DDR (1GB is a Spare)
Video Card(s) XFX 512MB Nvidia 7300LE
Storage 80GB Seagate, 200GB Seagate, 320GB Western Digital
Display(s) Chimei 22" LCD
Case Standard w/ LCD Display
Power Supply 650W Codgen
Software Windows XP Pro SP3
I've been having the exact same problem with my 320GB WD SATA drive and I'm bloody confused why cause its a brand new disk
zonc
10 (0.00/day)
YES! I've finally sorted this out. I ran into this accidentally, when switched SATA plugs and than the other disc started freaking out. Than i thought maybe it has to do with the sata plugs? i've tested all of the slots, and one of the four caused system crashes, reboots, "delayed write" failures and so on. Now this one is unused, both discs plugged to one controller and it is RUNNING AS GOLD :) many hours of downloading files, just finished playing 5 hrs of Crysis and totallly no problems. I'm so happy now :toast:
Solaris17
27,610 (3.84/day)
Alabama
VR HMD Quest 3
good job dude glad you figured it out :) :toast:
