Destination host unreachable - SOLVED
15 (0.01/day)
System Name Alder
Processor Intel Core i5-12400F @ 4.4GHz (Cooler: Deepcool AK400)
Motherboard MSI PRO B660-A DDR4
Cooling 2x be quiet! Silent Wings 3 140mm High-Speed (Intake), 2x Corsair AirGuide 120mm (Exhaust)
Memory Corsair Vengeance LPX 16GB (2x8, CL16) @ 3200 MT/s
Video Card(s) MSI NVIDIA GeForce RTX 3070 Gaming X Trio
Storage Crucial P2 1TB NVME
Display(s) AOC 24G2W1G4 - 1920x1080@144hz, PHILIPS 193V5 1920x1080@60hz
Case Corsair 4000D Airflow
Audio Device(s) Sharkoon Gaming DAC Pro S V2
Power Supply Seasonic Focus GX-650 (80+ Gold)
Mouse Glorious Model O
Keyboard Corsair K70 Platinum MK.2
Software Windows 11 Pro 22H2
I'm trying to run Kodi on a Windows-based HTPC over WiFi and I wanted to use my phone (with Kore) as a remote control cause it's a little more convenient than using just a wireless mouse.
was confused as to why my phone wasn't at all recognising the server, despite it being set up correctly, then I tried pinging the local ip address in Termux (used nmap too to no avail) and it read Destination host unreachable.
i could access the web-server from my desktop, and even ping it.
as a test, I tried putting the WiFi adapter that my HTPC uses into my own PC and disabled the Ethernet adapter just in case.
i tried pinging the IP again (after making sure it was the same in both ipconfig and on my router page) and it still didn't work.
I can ping from my desktop (ethernet) to my phone (wifi), and from my desktop (ethernet) to my HTPC (wifi), but can't ping from my phone (wifi) to my HTPC (wifi).
any suggestions? btw already tried using iptables, allowed it and it still doesn't work AP Isolation isn't turned on either
73 (0.04/day)
System Name Carnival of Glass
Processor Intel i9 14900K (previously 12900K/9900K, 8086K/Xeon X5670)
Motherboard ASRock Z790 PG SONIC (Gigabyte Z690 Aorus Master, Gigabyte Z370 Aorus Gaming 7/390 Des/X58A-UD7)
Cooling Corsair Hydro open loop, 480mm XR7, 360mm XR5!
Memory 32GB Corsair Dominator 6000MT DDR5 @6466 CL36-38-38-72-114-2
Video Card(s) Zotac RTX 3090 w/Corsair XG7 block (previously 1080Ti/970) +200 core +800 RAM +shunt mod
Storage 1x 2TB Samsung Evo 980 boot, 2TB Sabrent RQ, 2x2TB Crucial MX, 2x4TB WD SN850X, 16TB NAS!
Display(s) Acer Nitro 27" 4K, Koorui 27" 2K144Hz Acer 24" 1080p LED, 65" and 55" 4K TVs
Case Corsair 7000X (previously Corsair X570 Crystal SE)
Audio Device(s) Onboard + EVGA Nu Audio Pro 7.1, Yamaha Y2K AV Amp, Rotel RX-970B + 4x Kef Coda IIIs :D
Power Supply Corsair HX1500i Modular PSU
Mouse Corsair Darkstar/M65/Logitech G502 Lightspeed (previously G600 MMO)
Keyboard Corsair K70 Pro Optomech Axon, Logitech G910 Orion Spectrum (previously G19)
VR HMD HTC Vive Cosmos x2
Software Windows 11 x64 Enterprise (legal!)
Benchmark Scores https://www.3dmark.com/spy/18709841 https://valid.x86.fr/s9zmw1 https://valid.x86.fr/t0vrwy
Global port forwarding?
1,264 (0.20/day)
Hampton Roads
Processor Xeon x5650
Motherboard SABERTOOTH X58
Cooling Fans
Memory 24 GB Kingston HyperX 1600
Video Card(s) GTX 1060 3GB
Storage small ssd
Display(s) Dell 2001F, BenQ short throw
Case Lian Li
Power Supply X750
Software Mint 19.3, Win 10
Benchmark Scores not so fast...
VPN? Also, try to log into router from your phone. Or at least get to the login page
Edit...
Try turning mobile data, 5g or LTE, or whatever, to off.
15 (0.01/day)
System Name Alder
nope, that makes it work when I use the public IP but I'm trying to access something using the local IP address of my device
currently I'm more focused on getting an actual ICMP response
Edit...
logging into router works, no VPN on
tried aeroplane mode + wifi and still didn't work
as an update: I troubleshooted the issue with 3 lovely fellows from /r/sysadmin and we came to the conclusion that it's most likely an issue with my router, but we're all unsure
we noticed that ARP entries were missing and that after manually adding to both ARP tables the mac address of both the phone and the home theater PC respectively they were able to establish a connection and my issue got 'solved'
but that still leaves the mysterious missing ARP entries
73 (0.04/day)
Well, i was going to say your router, but i thought you would have already known that? Hah... Open Source firmware bullshit?
15 (0.01/day)
System Name Alder
honestly, might just be the router. I'm thinking of doing a factory reset on it, but I don't know how much that would help
I realised I can't ping my phone either from my main rig unless I ping my main rig first via termux on my phone, then it works
I can't ping my home theater PC at all using my phone, but I can do it just fine using my main rig. idk whats going on
wireless networking - Two devices cannot ping each other through WiFi - Super User
Windows 10: Unable to Ping and missing arp table entry mystery - Microsoft Community
looks like a factory reset might do the trick
bug
14,343 (3.95/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
Is everything connected to the same network? I have had problems in the past when I combined the 2.4 and 5GHz networks some (stupid) devices just wouldn't connect properly anymore.
Otherwise, just try traceroute/tracepath.
15 (0.01/day)
System Name Alder
Everything was connected to the same network, same 2.4GHz / 5GHz (dual-band) access point
I just did a factory reset and everything works okay now, don't know why that even happened because everything seemed 'right' in the router settings
Earlier I also tried turning off the 5 GHz band and only using the 2.4 GHz one, and that solved nothing so I just think it was a firmware bug or something similar.
bug
14,343 (3.95/day)
Yeah, the software/firmware probably choked on something. I still await the day when we'll have the first router that doesn't do that.
15 (0.01/day)
System Name Alder
I'm just happy a factory reset did the trick, because I was worried it might've been something similar to what Huawei sometimes does on their routers (I've heard that even though AP Isolation is off sometimes it can block connections between multiple wireless devices)
73 (0.04/day)
Kinda funny you're having router issues.. A while ago i wanted a better Access Point/better WiFi and was using an old ASUS, built my own router which was pfSense, then OPNSense to counter Realtek adapter issues, then switched to Intel and Broadcom NICs... So, i did have a router that didn't take a crap on a software choke! Switched to a Netgear R8000 and installed FreshTomato, which initially softbricked and i had to connect to the RS232 header to repair it.. Embedded Linux devices can be good but...wow. BSD Unix is my go-to for a reason :)
Open Source...heh. Not worth the money! The WiFi radios constantly sit at 53C and the CPU at 72C...not exactly new but its a POS!
I also switched all my cables to Cat8, that helped with impedance mismatches and packet issues at least :)
