- Apr 7, 2008
- 633 (0.10/day)
- Australia
System Name | _Speedforce_ (Successor to Strike-X, 4LI3NBR33D-H, Core-iH7 & Nemesis-H) |
Processor | Intel Core i9 7980XE (Lapped) @ 5.2Ghz With XSPC Raystorm (Lapped) |
Motherboard | Asus Rampage VI Extreme (XSPC Watercooled) - Custom Heatsinks (Lapped) |
Cooling | XSPC Custom Water Cooling + Custom Air Cooling (From Delta 220's TFB1212GHE to Spal 30101504&5) |
Memory | 8x 8Gb G.Skill Trident Z RGB 4266MHz @ 4667Mhz (2x F4-4266C17Q-32GTZR) |
Video Card(s) | 3x Asus GTX1080 Ti (Lapped) With Customised EK Waterblock (Lapped) + Custom heatsinks (Lapped) |
Storage | 1x Samsung 970 EVO 2TB - 2280 (Hyper M.2 x16 Card), 7x Samsung 860 Pro 4Tb |
Display(s) | 6x Asus ROG Swift PG348Q |
Case | Aerocool Strike X (Modified) |
Audio Device(s) | Creative Sound BlasterX AE-5 & Aurvana XFi Headphones |
Power Supply | 2x Corsair AX1500i With Custom Sheilding, Custom Switching Unit. Braided Cables. |
Mouse | Razer Copperhead + R.A.T 9 |
Keyboard | Ideazon Zboard + Optimus Maximus. Logitech G13. |
Software | w10 Pro x64. |
Benchmark Scores | pppft, gotta see it to believe it. . . |
Hi everyone,
I recently killed my mainboard whilst playing around inside the case by shorting it out.
I have (had) the Asus X99-E WS which i was very happy with, especially for overclocking. Now i need a replacement and although i would normally be more than happy to go back to the same board, i thought i should ask you guys for your opinion on a replacement.
At the moment, i have the Asus X99-E WS in-mind, as well as the ASRock X99 Extreme 11.
My requirements are;
3-Way SLi-Crossfire. Sometimes i take out the PCi-E Flashmax and run the 3rd card, depends on what i am in the mood for.
1 Pci-e x8/16 slot for my Sound Card.
8 DiMM slots.
The rest should be pretty standard like, minimum 8x USB 3.0 (or more), 8 SATA3 Ports (or more), Dual Ethernet Ports and some decent overclocking ability.
I plan do re-use my existing XSPC water-cooling setup and i am willing to buy new mainboard/Chipset waterblocks. My case has no physical limitations and the rest of my hardware should suit just fine.
What do you guys have, what do you think, what would you buy in my position ?
8 DiMM slots.
