- Sep 5, 2004
- 1,959 (0.26/day)
- The Kingdom of Norway
Processor | Ryzen 5900X |
Motherboard | Gigabyte B550I AORUS PRO AX 1.1 |
Cooling | Noctua NB-U12A |
Memory | 2x 32GB Fury DDR4 3200mhz |
Video Card(s) | PowerColor Radeon 7800 XT Hellhound |
Storage | Kingston FURY Renegade 2TB PCIe 4.0 |
Display(s) | 2x Dell U2412M |
Case | Phanteks P400A |
Audio Device(s) | Hifimediy Sabre 9018 USB DAC |
Power Supply | Corsair AX850 (from 2012) |
Software | Windows 10? |
would been nice if there was HIP and HIP-RT under Computing
AMD HIP SDK for Windows
HIP Documentation — HIP Documentation (amd.com)
HIP Ray Tracing - AMD GPUOpen
Requirements
HIP RT runs on AMD and NVIDIA® GPUs. HIP and CUDA® APIs are dynamically loaded so you do not need to have these SDKs if your have these dlls installed with the driver package. Hardware accelerated ray-tracing only works on RDNA™ 2 GPUs (Radeon™ RX 6000 series or newer).
It works on AMD GPUs which supports HIP. The supported AMD GPUs are
You will also need AMD Software: Adrenalin Edition 21.40 or later.
- Navi3x (Radeon RX 7000 series).
- Navi2x (Radeon RX 6000 series).
- Navi1x (Radeon RX 5000 series).
- Vega2x.
- Vega1x.
