Difference between directX 10 and 11
3,352 (0.60/day)
System Name Dark Stealth
Processor Ryzen 5 5600x
Motherboard Gigabyte B450M Gaming rev 1.0
Cooling Snowman, arctic p12 x2 fans
Memory 16x2 DDR4 Corsair Dominator Pro
Video Card(s) 3080 10gb
Storage 2TB NVME PCIE 4.0 Crucial P3 Plus, 1TB Crucial MX500 SSD, 4TB WD RED HDD
Display(s) HP Omen 34c (34" monitor 3440x1440 165Hz VA panel)
Case Zalman S2
Power Supply Corsair 750TX
Mouse Logitech pro superlight, mx mouse s3, Razer Basiliskx with battery
Keyboard Custom mechanical keyboard tm680
Benchmark Scores 70-80 fps 3440x1440 on cyberpunk 2077 max settings
Actually i have heard there are not enough games in direct x 11 but i want to know more about the direct x 11 advantages and what are the games that support it
CDdude55
Crazy 4 TPU!!!
8,178 (1.26/day)
Virginia
System Name CDdude's Rig!
Processor AMD Athlon II X4 620
Motherboard Gigabyte GA-990FXA-UD3
Cooling Corsair H70
Memory 8GB Corsair Vengence @1600mhz
Video Card(s) XFX HD 6970 2GB
Storage OCZ Agility 3 60GB SSD/WD Velociraptor 300GB
Display(s) ASUS VH232H 23" 1920x1080
Case Cooler Master CM690 (w/ side window)
Audio Device(s) Onboard (It sounds fine)
Power Supply Corsair 850TX
Software Windows 7 Home Premium 64bit SP1
There are not enough games in DX11 because its still in it's early stages of release. Once newer games start rolling out and demand for more visually impressive scenery starts being put into effect, DX11 will be utilized in much more games. As of now only a few games have support for DX11,(Dirt 2, Battleforge..etc), but several games have been announced to support DX11 and you should see a good amount of titles with DX11 support be released in 2010.
The main difference is the use of Tessellation in DX11. It helps round out and make surfaces look much more realistic and detailed in game. DX11 also helps in other ares like multi-threaded games and shading.
Its a pretty big leap from DX10, as DX10 really didn't offer much of an eye-candy boost or any specific features that pulled it ahead of DX9.
913 (0.16/day)
Baltimore, MD
System Name Cool Runnings Mark 2
Processor i7 4770k No OC
Motherboard MSI Z87 MPower
Cooling Noctua NH-D14
Memory GSkill TridentX 2400MHz 32GB
Video Card(s) MSI GTX 1070 Ti Duke, EVGA GTX 780 AC+
Storage Crucial MX500 1TB SSD, 3 more HDDs
Display(s) 2x MSI 32" 2560 x 1440 144Hz Optix MAG321CQR, Acer G276HLDbd Black 27" 6ms
Case Corsair 600t
Power Supply Corsair HX850
Mouse Razer DeathAdder
Keyboard Steelseries Merc Stealth
Software Win10 Pro 64-bit
yeah dx10 was useless, and in my experience, buggy. most of the games i had that were dx10 i just played in dx9 and was just as happy
some quick googling turned up:
http://en.wikipedia.org/wiki/Directx#DirectX_11
http://blogs.amd.com/play/2009/06/02/why-we-should-get-excited-about-directx-11/
http://www.bit-tech.net/bits/2008/09/17/directx-11-a-look-at-what-s-coming/1
basically directx11 will make the processing of graphics quicker and more efficient, as well as prettier and more life like. dx11 is what dx10 was originally supposed to be
and i think that there are plenty of games coming out in dx11, it just isnt the industry standard that dx9 is yet
see http://forums.techpowerup.com/showthread.php?t=103614&highlight=directx+11 for a list of game in dx11
6,535 (1.11/day)
Midlands,UK
System Name Reborn|Partner
Processor AMD Ryzen 9600x|AMD Ryzen 7 5700x
Motherboard Asrock B650m Pro-RS|Asus B550m Prime Wifi
Cooling Arctic cooling freezer 34 white + Montech 120mm | Thermalright Silversoul 135 + Corsair 140mm white
Memory Corsair Vengeance DDR5 32GB 6000mhz|Corsair Vengeance DDR4 16GB 3200mhz
Video Card(s) XFX AMD RX 9070XT Swift Black 16GB| Zotac Nvidia RTX 4080 Super Trinity black edition 16GB
Storage 2x2TB WD Black SN1700|WD Blue 500GB NVME,Kingston 240GB SSD,2TB Corsair NVME
Display(s) AOC Gaming CU34G3S/BK | Iiyama XUB2792QSU gen 2 + Iiyama XUB2792QSU gen 1
Case Montech Air 100 White| Corsair Carbide Air 240 White
Audio Device(s) onboard/Speakers: Logitech G560 | onboard/Speakers: Sanyun SW208 white 2.0
Power Supply Seasonic Focus GX 850w Gold Modular | Corsair RMx White 750w Gold Modular
Mouse Microsoft Pro Intellimouse shadow | Razer Deathadder Essential white
Keyboard Epomaker mechanical keyboard| Razer huntsman v2
isn't direct X11 suppose to be more optimized than DX10? if so it run just like Dx9 and get good Frame rate.
3,352 (0.60/day)
Case Zalman S2
It needs more power than Direct X 9 because of the tools being used, so the frame rates in directX9 will be more if u use a directx11 card
4,876 (0.78/day)
Joplin, Mo
System Name Ultrabeast GX2
Processor Intel Core 2 Duo E8500 @ 4.0GHZ 24/7
Motherboard Gigabit P35-DS3L
Cooling Rosewill RX24, Dual Slot Vid, Fan control
Memory 2x1gb 1066mhz@850MHZ DDR2
Video Card(s) 9800GX2 @ 690/1040
Storage 750/250/250/200 all WD 7200
Display(s) 24" DCLCD 2ms 1200p
Case Apevia
Audio Device(s) 7.1 Digital on-board, 5.1 digital hooked up
Power Supply 700W RAIDMAXXX SLI
Software winXP Pro
Benchmark Scores 17749 3DM06
directx 10 should have never been released as direct x 10, rather just another revision from 9.
There were more changes between directx9 and its revisions, than direct x 10. If I were to guess, direct x 10 was released in support of windows vista.
3,352 (0.60/day)
Case Zalman S2
so it needs to be named direct x 9d :)
Polarman
1,626 (0.26/day)
Rimouski
System Name Polar's Dragon
Processor AMD Phenom II 975BE
Motherboard MSI 890FXA-GD65 (Bios 18.7)
Cooling Zalman CNPS 9700 Led
Memory Gskill 8GB DDR3-1333 (8,8,8,21)
Video Card(s) MSI HD6870 Hawk
Storage WD Raptor 250 - WD RE4 500GB
Display(s) Samsung T240 (1920 X1200)
Case Silverstone Raven 2
Power Supply PC Power&Cooling Silencer 750 (Red)
Software Windows 7 Home Premium 64Bit + SP1
DirectX 10:
- Fixed pipelines are being done away with in favor of fully programmable pipelines (often referred to as unified pipeline architecture), which can be programmed to emulate the same.
- New state object to enable (mostly) the CPU to change states efficiently.
- Shader model 4.0, enhances the programmability of the graphics pipeline. It adds instructions for integer and bitwise calculations.
- Geometry shaders, which work on adjacent triangles which form a mesh.
- Texture arrays enable swapping of textures in GPU without CPU intervention.
- Predicated Rendering allows drawing calls to be ignored based on some other conditions. This enables rapid occlusion culling, which prevents objects from being rendered if it is not visible or too far to be visible.
- Instancing 2.0 support, allowing multiple instances of similar meshes, such as armies, or grass or trees, to be rendered in a single draw call, reducing the processing time needed for multiple similar objects to that of a single one.
DirectX 10.1:
- Mandatory 32-bit floating point filtering.
- Mandatory support for 4x anti-aliasing
- Shader model 4.1
DirectX 11:
- Tessellation to increase at runtime the number of visible polygons from a low detail polygonal model.
- Multithreaded rendering to render to the same Direct3D device object from different threads for multi core CPUs.
- Compute shaders which exposes the shader pipeline for non-graphical tasks such as stream processing and physics acceleration, similar in spirit to what OpenCL, NVIDIA CUDA, ATI Stream achieves, and HLSL Shader Model 5 among others.
- Two new texture compression algorithms for more efficient packing of high quality and HDR/alpha textures and an increased texture cache.
All this info was on Wiki.
11,098 (1.74/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
BababooeyHTJ
907 (0.15/day)
Processor i5 3570k
Motherboard Gigabyte Z77 UD5h
Cooling XSPC Raystrom
Memory 4x4GB DDR3 1600mhz
Video Card(s) 7950 crossfire
Storage a few
Display(s) 27" Catleap
Case Xigmatek Elysium
Audio Device(s) Xonar STX
Power Supply Seasonic X1050
Software Windows 7 X64
So, DX10 was useless and buggy because early DX9 games that were shoddily ported over to DX10 in it's early days like Crysis didn't run as well as in DX9? You might want to check out games like Far Cry 2, Assassins Creed, Hawx, etc before making such a statement. Those games actually look better in DX10 while seeing better performance with AA than in DX9.
Hopefully 7 takes off so we will see more DX11 adoption. Vista's reputation is what killed DX10.
310 (0.05/day)
System Name Junkamatic
Processor i7
Motherboard Z77
Cooling Thermaltake
Memory Corsair
Video Card(s) Evga GTX770
Storage 4 Seagate Satas
Display(s) VW266H
Case Lian-Li A77B
Audio Device(s) on-board
Power Supply Corsair HX1000w
Software W7
6,535 (1.11/day)
Midlands,UK
i have to say Resident evil 5 on the PC in DX10 was quite optimized,when i look at Frame rate score its pretty good and same with HAWX
5,968 (0.93/day)
New York
Processor AMD Ryzen 9 9950x / AMD Epyc 7773x
Motherboard Gigabyte B850 Gaming X/ ASROCK ROME
Cooling Be Quiet Dark Rock Pro 4(Custom) / Custom Air
Memory 64GB Crucial Pro 6400 / 384GB
Video Card(s) MSI RTX5070Ti(Temporary)/ 4X RTX3090
Storage Adata SX8200 1TB NVME/WD Black 1TB NVME
Display(s) Dell 27 Inch 165Hz
Case Lian Li A3 Mini
Audio Device(s) IFI Zen Dac/JDS Labs Atom+/SMSL Amp+Rivers Audio
Mouse Logitech G502 SE Hero
Keyboard Corsair K70 RGB Mk.2
VR HMD Samsung Odyssey Plus/ Quest 3
DX11 is more about increased efficiency, by making the games run better they can make them look better with nowhere near as much of a performance hit, but id does add some features like DX compute also
7,238 (1.06/day)
Memory 2GB DDR // 8GB FB-DIMM
Audio Device(s) Audigy 2
The major change with DX11 that will have a significant impact in future games engines is: Multithreaded rendering to render to the same Direct3D device object from different threads for multi core CPUs. Finally we will see big improvements in Quad Core and higher CPU's over Single and Dual Core CPUs. To date, multicore tech has only helped with offloading sound or AI to a different core... or with texture unzipping. Now, finally, we can get the "engine" to be truly multithreaded.
Tesselation is old hat and was called TruForm and was available since ATI Radeon 8500, ie. before 9700, X800, X1950, HD2xxx, HD3xxx, HD4xxx and now HD 5xxx... ie. it is already 8 generations old.
