Difference between palit dual and super jetstream?
2,071 (0.44/day)
Denmark
Processor I5 13400f
Motherboard Gigabyte Z790 D AX
Cooling Thermalright Assassin X120 R SE Black
Memory G.Skill Ripjaws S5 DDR5-6400 - 32GB - CL32
Video Card(s) Asus GeForce® RTX 5060 Ti 16GB Prime
Storage 1x2tb KC3000 & 2tb samsung 970 evo plus, 2 x 2 tb external usb harddrives
Display(s) LG 32GP850, IIyama G2470HSU-B1
Case DUTZO C731 Mesh TG ARGB
Audio Device(s) Yamaha R-N800A System audio signature 5 + Audio pro addon sub 1
Power Supply Corsair RM850X White
Mouse Asus Rog Gladius III Wireless Aimpoint
Keyboard Corsair K70 RGB TKL Champion
Software Windows 11 64 bit
Ordered me a palit gtx 1060 dual instaead of the super jetstream beacuse it was the cheapest on the site where i wanted to buy a gtx 1060
Google couldn't help me, mabye you can, what is the difference between palit dual gtx 1060 and super jetstream?
I forgot the jetstream and dual they have the same stock speed
Is jeststream cooler, i now see it's a 2.5 slot card
If you look at the gallery, the Jetstream has 4 heatpipes, has a backplate and a dual bios switch, plus the Jetstream has a beefier cooler vs the dual. Another that was probably not seen is the power limit, the Jetstream and Super Jetstream may have higher limit than the dual and the Super jetstream is same with the regular but with even higher power limit.
In my case i just got the Super jetstream 1070 and be done with it (Gamerock is not my liking heh)
Just make sure if you get a Jetstream you are prepared for a 3 slot cooler
Must admi't i cant see any pictures of the back of the palit dual, deos DR Mos make a difference?
Probably because nothing to show off there as it lacks a backplate. Not sure if DR Mos makes any difference really
Atleast it should be silent, even the Palit GTX 1080 GameRock Premium 8 GB is extermly silent 30 db as good as the gtx 980 from asus/msi
Does anybody know why the card 0 db fan is limited to 50 degresse (asud 65)
0db fan has my card as well, I'm using a custom fan profile with afterburner, no need for me to let it idle so warm during summertime.
The fans are quiet anyway.
You could always modify the fan curve, make it start spinning at a specific temp or just make it spin all the time
just wondering why palit choosed 50 degresse compared to asus or msi with 60 or higher
Im extremy surprised about my evga gtx 960 ssc 4gb 26-27% fan and 70 dergresse doing gaming
in a define r5 (3x 140mm noctu 500 rpm fans, cpu cooler the big on from nuctua 350 rpm), they are silent
like you wouldn't belive it, amazing
94 is max with a gtx 1060, my gtx 960 only get's around 70 degresse doing gaming.
When does it throttel? At what temps?
Not sure about that, I never had a card throttle because I make sure they run as cool as possible.
not fan of the hot cards, had a msi gtx 980 ti 65% fan speed, it thottled in a define r5 when it was 30-32 degress in my livingroom, 65% speedfan was way to noisy
I never want that kind of hot gpu again
heard someone on another site say it thottles at 75 c , might not set it higher then 60 c before fans start spinning
I just got the Palit Dual, it's a nice card. The main difference between it and the SuperJetStream is that it has a smaller cooler, no backplate and no bios switch.
The temps don't go above 75 C when overclocked and you can set the temp limit to 92 C using Afterburner/Precision.
You 'might' get slightly more overclocking potential with the SuperJetStream, but I can't imagine it would be very much. Mine is at 1908/2260 stable. I haven't had the time or will to tweak more, but I think I can get a little more out of the core if I wanted.
Might only oc it so it performs like the super jetstream, thats it
Techpowerup say theres a huge difference between the gtx 960 and 1060 (my gtx 960 is a ssc card,so when i oc the dual card a bit the difference might still be the same), i play a game like need for speed shift 2 unleashed, at medium setting (aa16x) i get around 55-60fps min/max is 50/65 in 3440x1440, since it's a 100hz monitor i would like to go noticeable above 60 fps
Im a bit surprised of the difference, when the msi gtx 1060 get's 100% (stock 97%) in 3840x2160 the gtx 1060 get's only 48%
that is actually very close or more than 100% more fps with a gtx 1060 over a gtx 960, where a gtx 970 thats is surpose to be alot faster than a gtx 960 only gets around 50% more fps then gtx 960, thats much better then adding a second gpu (which need for speed shift 2 doesn't support)
Can't wait to see the performance of then gtx 1080 ti, some say it's a HUGE perfomance gain over the 1080 might even be as high as 50% and mabye the first single card to be good for uhd/4k gaming
Yeah. The 1060 is easily twice the performance of the 960.
As i allready mentioned im not gonna extreme oc it, mabyte to the super jetstream oc
Once used 2x msi gtx 960 that i had no problems with the heat and noise just had a couple of games that didn't support sli
Congrats with your new card!
Time to update your system specs :)
Happy gaming!:clap:
Havn't recived it., just ordered it's so new not everybody has one in stock
get the EVGA GTX 1060 SC ACX copper
60c temps
2000mhz peak boost
230 bucks after rebates
