NovaProspekt
- Nov 9, 2017
- 20 (0.01/day)
Hello everyone,
As the title states, I have been having a very hard time getting my card to run stable. I have the Gigabyte reference model Vega 56, which I have flashed to the Vega 64 BIOS. I have been scouring forums for months looking at Vega undervolting/overclocking guides, and pretty much everyone seems to be having great success.
My games crash to desktop even at the "stock" (Vega 64 BIOS default) Wattman settings. It seems like no matter how I go about trying to find a stable voltage/frequency combination I cannot get the card to run stable. I have been using GPU-Z to monitor the card and the core temp never exceeds 70C (though the "hot spot" temp often reaches 105C).
Here is the latest screenshot of what my Wattman setting look like. I have the P6 and P7 states set to the same values because I am trying the most recent guide advice I found, which is to set the P6 and P7 states to the P6 default values, then gradually decrease voltages by the same amount on both states together to find the optimum P6 undervolt, then increase P7 to the default values and start lowering P7 voltage. However, even with P6 and P7 set to the P6 defaults, Destiny 2 crashes to desktop within minutes. Have I just gotten really unlucky and ended up with a chip that barely passed AMD quality control?
I am starting to wonder if maybe the problem might be my CPU overclock (i5 3570k @ 4.4 Ghz), but that's been running solid since 2012 so I'm pretty confident in it. I tried running some Prime95 tests just to reassure myself, but it's summer and there's no AC in my office so Prime95 quickly puts the CPU over 90 degrees C (temps monitored via CoreTemp), which I don't want to sustain. The temps never get much over 60 degrees C due to a real world gaming load.
Any advice would be very welcomed.
Thanks
Probably the answer is to flash back to the stock Vega 56 BIOS and see if the stability problems go away right?
Thanks
