DirectCompute 4.1 checkbox
78 (0.01/day)
Toronto, Canada
Processor Intel Core 2 Extreme QX9650
Motherboard ASUS P5Q DELUXE
Cooling Zalman CNPS9900A
Memory 8GB Mushkin DDR2-1066
Video Card(s) Sapphire Radeon 4870 512MB
Storage 2x WD 500GB 32MB cache
Display(s) Benq V2400W 24"
Case Cooler Master 690
Audio Device(s) Creative SoundBlaster X-Fi Fatal1ty
Power Supply Cooler Master 550W
Software Windows 7 Professional 64-bit
Benchmark Scores Benchmarking is for people with OCD.
Hey, I just updated to Windows 7 from Windows XP and I when I ran GPU-Z I noticed the DirectCompute 4.1 check box was ticked. On Windows XP it was not ticked. Why did it change after I upgraded? Is it because Windows XP has DirectX 9 and the 10.1 options are not detected?
I am using an ATI Radeon 4870 512 MB.
it could be the driver you were using,
the box's that are ticked for my card change a lot depending on the driver and how its installed.
(had issues getting cuda to work for a wile)
either that or direct compute isnt supported under xp but i think Option one is more likely.
I was using the Catalyst 9.12 driver on each OS. Everything was the same except the OS. That's why I found the behaviour weird.
dxcompute is only available when dx 11 runtimes are installed. xp -> no dx 11 -> no dx compute. vista -> no dx 11 -> install dx 11 patch thingie -> dx compute
you also need support for it from the driver
OK I see, that's what I thought. Then why show the checkbox at all in Windows XP if it can never be shown as checked? I think it should be removed if the OS is XP.
removing it will probably create more "where the checkbox threads" than there are "where is the checkmark" threads :)
