DirectX 12
65 (0.02/day)
Processor Intel Core I5 6400
Motherboard MSI Z170A PC MATE
Cooling Cooler Master Hyper T4
Memory Kingston HyperX Fury 8GB 2400Mhz
Video Card(s) MSI Gaming 4G GTX 970
Storage WD GREEN 1TB, ADATA SP550 120GB
Case NZXT Source 210
Power Supply Thermaltake SMART Series 430
Hello, I want to ask what's happening with DirectX 12 and which GPUs will have full support because I was thinking of buying a GTX 770 but this DirectX 12 think is stopping me to buy a GPU from 700 series and spend more to GTX 960 which is more expensive but also slower in my country. So what are your suggestions guys?
rtwjunkie
PC Gaming Enthusiast
14,034 (2.29/day)
Louisiana
Processor Core i9-9900k
On the Nvidia side, which is what you are asking about, GPU's back to Fermi are expected to get DX12, so the 770 (Kepler) definately falls in there.
The unknown I think (and I could be wrong), we don't know what features, if any will be cut from DX12 when it releases for Fermi and Kepler.
2,098 (0.51/day)
System Name Ryzen 2023
Processor AMD Ryzen 7 7700
Motherboard Asrock B650E Steel Legend Wifi
Memory G Skill Flare X5 2x16gb cl32@6000 MHz
Video Card(s) Sapphire Radeon RX 6950 XT Nitro + gaming Oc
Storage WESTERN DIGITAL 1TB 64MB 7k SATA600 Blue WD10EZEX, WD Black SN850X 1Tb nvme
Display(s) LG 27GP850P-B
Case Corsair 5000D airflow tempered glass
Power Supply Seasonic Prime GX-850W
Mouse A4Tech V7M bloody
Keyboard Genius KB-G255
Software Windows 10 64bit
I believe most will support DX 12.1 with no problem but I might be wrong
65 (0.02/day)
http://wccftech.com/amd-confirms-gc...-level-111-gcn-10-feature-level-120-gcn-1112/ in this site I saw that only maxwell will support 12.1 and any other GPU will support DirectX 12, Feature level 11 and partial feature level 11.1 which is bad I think.
2,098 (0.51/day)
This looks interesting:
The reference DirectX 12 API (Feature Level 11_0) has performance targeted features while the other two level deliver graphical improvement and this is what really matters in improving the games visually. The feature level 12_0 comes with Tiled Resources, Typed UAV Access and Bindless Textures support. Feature Level 12_1 has the Raster Order Views.
AMD has recently confirmed that their current cards can support Feature Level 12_0 at best while NVIDIA’s Maxwell 2.0 architecture has support for Feature Level 12_1. The cards that feature level 12_ 0 support include Radeon HD 7790, Radeon R7 260 (X), Radeon R9 285, Radeon R9 290 (X) and R9 295X2. The older cards such as the ones based on Tahiti, Pitcairn that include all the 7000 series cards (excluding HD 7790), Radeon R9 270 (X) and Radeon R9 280 (X) feature up to Feature Level 11_1 support. Robert Hallock believes that there’s no problem with not feature DirectX Feature Level 12_1 support since features are performance enhancing tools are already available in 11_1 and 12_0 and most games won’t rely on utilization of 12_1.
According to Hallock, the absence of the feature level 12_1 is no problem in principle. So the key for games features are all included in the feature level 11_1 and 12_0. In addition, most games would already geared to the console and thus hardly rely on 12_1.
This however could hurt AMD in the long run against Maxwell (GeForce 900 series) cards that are compliant with DirectX 12 feature level 12_1 and that was proved in their recent GeForce GTX 980 Ti launch. NVIDIA’s older cards, such as Kepler and Fermi come with Feature Level 11_0 support with partial Feature Level 11_1 support.
Not like I plan to go the windows 10/ Direct X 12 way anyway. I dont like it will be subscription based.
rtwjunkie
14,034 (2.29/day)
Louisiana
I would not consider it bad. 12, I believe, will bring all the improvements for earlier games, and i expect that 770 you want to be obsolete before game makers are making 12.1 games en masse. Just my opinion though. There will be more views throughout the day here, just be patient.
65 (0.02/day)
I'm patient :D
2,098 (0.51/day)
What card do you have now?
65 (0.02/day)
Old Sapphire HD 6950 2GB With Pentium G3258 at 4.4 - 4.6Ghz, Asus H81M-C, Corsair 2x4GB 1600Mhz and Thermaltake Smart Series 430w.
18,584 (2.63/day)
System Name AlderLake
65 (0.02/day)
2,098 (0.51/day)
65 (0.02/day)
So is the 680 or 770 still worth buying?
1,465 (0.31/day)
Processor i7-13700k (undervolts -0.140 volts)
Motherboard Asus Tuf Gaming z790-plus
Cooling Coolermaster Hyper 212 RGB
Memory Corsair Vengeance RGB 32GB DDR5 7000mhz
Video Card(s) Asus Dual Geforce RTX 4070 Super ( 2800mhz @ 1.0volt, ~60mhz overlock -.1volts)
Storage 1x Samsung 980 Pro PCIe4 NVme, 2x Samsung 1tb 850evo SSD, 3x WD drives, 2 seagate
Display(s) Acer Predator XB273u 27inch IPS G-Sync 165hz
Audio Device(s) Logitech Z906 5.1
Power Supply Corsair RMx Series RM850x (OCZ Z series PSU retired after 13 years of service)
Mouse Logitech G502 hero
Keyboard Logitech G710+
Um Lets make this 100% clear. DX12 on nvidia side need 900 series to support all of it. The part of DX12 that 770 supports will be the speed improvements, the lower level stuff. All DX11 cards can least do that part of DX12. But not dx12 graphical things.
instead of a gtx770, might want to spend little extra to get 970 or gtx960, 960 should be pretty close performance wise to 770.
INSTG8R
Vanguard Beta Tester
8,150 (1.09/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 3
Software Win 11 Pro x64
Well if DX12 is your priority your going for the oldest tech possible. Like rtwjunkie buy the time they are actually games utilizing it we could be on the next gen of cards. I mean DX11 exclusive titles took at least 5yrs to really be using DX11 properly.
1,465 (0.31/day)
With dx12 speed improvements, i expect more game Dev's will be lookin to least get that in use quick as it would open more for what they can do graphic wise in the game.
65 (0.02/day)
Well I'm buying second hand 770 and in my country the 970/960 are a lot more expensive than the 770/680 because there is nobody to sell them second hand :D
598 (0.12/day)
Pacific Rim
Processor Ryzen 3600
Motherboard B450
Cooling Scythe Ashura
Memory Team Dark Z 3200 8GB x2
Video Card(s) MSI 390
Storage WD 2TB + WD Green 640GB
Display(s) Samsung 40JU6600 @ 200% scaling
Case Coolermaster CM 690 II
Audio Device(s) Fiio E10K, Graham Slee Solo II SRG, Sennheiser HD6XX, AKG K7XX, ATH WS1100is
Power Supply Corsair HX650
Mouse Rival 700
Keyboard Corsair K70, Razer Tarantula
Then 770 is worth buying
65 (0.02/day)
Thermaltake smart series 430w enough for 770 the cpu is G3258 4.4Ghz after I buy GPU I will spend for i5.
MxPhenom 216
ASIC Engineer
13,172 (2.46/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27ACDNG 360Hz QD-OLED | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" 1440 IPS 1440p
Mouse Razer Viper v3 Pro
It should take far less time for dx12 titles to flood the market with the expected adoption rate of Windows 10 to be extremely high.
5,719 (1.08/day)
System Name Space Station
Processor Intel 13700K
Motherboard ASRock Z790 PG Riptide
Memory Corsair Vengeance 6400 2x16GB @ CL34
Video Card(s) PNY RTX 4080
Storage SSDs - Nextorage 4TB, Samsung EVO 970 500GB, Plextor M5Pro 128GB, HDDs - WD Black 6TB, 2x 1TB
Display(s) LG C3 OLED 42"
Case Corsair 7000D Airflow
Audio Device(s) Yamaha RX-V371
Power Supply SeaSonic Vertex 1200w Gold
Mouse Razer Basilisk V3
Keyboard Bloody B840-LK
Software Windows 11 Pro 23H2
I'm assuming most devs won't support Dx12.1 for at least a couple years or until AMD makes a 12.1 capable GPU.
I'm hoping to see a fair number of Dx12 games in 2016 though, even though my 7970 has only 2 ACE units and will probably only get half or less as much boost out of it as the newer cards.
1,465 (0.31/day)
Depends on if features help them, they could add it as option can be turned on and off like did for dx9/dx10/11 for some games.
Mussels
Freshwater Moderator
58,412 (7.78/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
The best way to explain it is that most DX11 cards get DX12 support - at least at the CPU side of things where the biggest gains are to be had.
Over time true DX12 cards (12.1 or whatever they call it) will come out with extra features, and they'll simply have greater performance than plain 12.0 (DX11) cards in newer titles.
65 (0.02/day)
So there is no need to buy expensive card at this time?
rtwjunkie
14,034 (2.29/day)
Louisiana
