Disabling automatic driver updates for GeForce on Win 10 Home
7,412 (2.55/day)
Poland
System Name Purple rain
Cooling Noctua D15S
Benchmark Scores A LOT
I've run into a problem which I already solved but I wanna ask around to make sure this doesn't happen again.
My GTX 1080 was running perfectly fine on 385.69 drivers, butter smooth for months both on Win 10 Home and 8.1 before. Today I noticed quite a lot of stutter in ME:Andromeda, after a while I saw my driver version was 388.13 which aere notorious for stuttering. The system must've updated the driver automatically. I uninstalled 388.13 and my system reverted back to 385.69 automatically. Everythings run smooth once again.
My question is: how do I stop this from happening again ? I'm okay with automatic updates for the system, chipset,RST and the like but GPU drivers I'd like to always install manually. I did what I found in this article
http://www.itprotoday.com/windows-server/stop-automatic-driver-updates-windows-10
but is this going to do what I'm asking for ? I'm a very inexperienced Win 10 user, I've only been on the new system for a month or two. Need advice.
You can't. I've tried literally everything that was said online to disable auto updating and Windows 8.x and 10 have a mind of its own. I had to test how far back some bug was appearing and Windows kept overriding my older drivers with some newer ones. It's fucking idiotic. Only way is to disconnect PC from internet.
and Windows 8.x
I have windows 8.1 on my desktop and have set updates to manual.
I can tell you that windows 8.1 does not download/install anything if you have set it to manual.
How is that relevant to my question ?
I was quoting RejZor as you could see...
Yes, I don't know what he is on to, I used 8.1 for years (up till October this year) and it never, never did automatic driver updates. I don't know what's wrong with this guy, he's always bitching so much about stuff, and often just making it up. can't even write a senetence without cursing something.
anyway, if there's no easy way to do that on win 10 then I'll just have to remebmer to check my driver version if my games show any malfunctioning.
also, the method I used was this
https://www.laptopmag.com/articles/disable-automatic-driver-downloads-on-windows-10
I copied a wrong link in my OP.
I've tried it on Win8.x as well like all the endless tutorials said online and it kept on overriding my Radeon drivers on laptop to latest version. Luckily Win10 works right with the drivers it delivers...
Registry edit.
HKEY_LOCAL_MACHINE –> SOFTWARE –> Microsoft –> Windows –> CurrentVersion –> DriverSearching -> SearchOrderConfig
Set to 0.
This works on my machines. Granted, they are all pro or enterprise, but try it anyways.
Registry edit.
Set to 0.
Thanks. I'll try if the problem reoccurs, now I'll leave it as is and see what happens.
Also, has anyone had any experience with 388.31 ? I think 388.13 was just a bad driver, I saw people reported stutter a lot. When I was on win 8.1 I used to update my drivers as soon as any new ones came out, and never had any issues. Only reason I didn't do that with 388.13 was that I saw people complain.
update:
I restarted my system and saw 388.13 again. What a turd this win 10 is.
Installing 388.31, hopefully this will fix it for now.
31 is running fine for me, but the only real NVIDIA specific feature I use is fast vsync.
388.31 is running very smoothly for me, along with nvidia control panel which I think was never that snappy as it is now. 388.13 was a mess, game stutter + nvcp was very unresponsive.
