Disk management console view is not up-to-date
$immond$
Alright I have finally set up my SSD + RAID 0 array, but I am unable to partition the RAID array or assign a drive letter. :(
Upon assigning a letter I get this message:
2xHDDs in RAID 0 640 GB
1X SSD 120 Gb Sandforce 1200
2,644 (0.44/day)
System Name MRCOMP!
Processor 5800X3D
Motherboard MSI Gaming Plus
Cooling Corsair 280 AIO
Memory 64GB 3600mhz
Video Card(s) GTX3060
Storage 1TB SSD
Display(s) Samsung Neo
Case No Case... just sitting on cardboard :D
Power Supply Antec 650w
i dont know how to fix your disk management, but i can fix your partition problems...
open up Command Prompt with admin rights. (Right click, run as admin)
enter in
DISKPART
list disk
then find the Disk number for your Raid array... lets call it number 7 ( you can tell what disk is what by the total size)
type in
Select Disk 7
List Partition (will give you a list of all the partitions..)
Select Partition 1 (im assuming you only have 1 partition on Disk 7) repeat this step if you have more partitions.
ASSIGN
that should get the array up and running ready to use.
EDITED.
any problems, post back ^^
Still EDITING :p
side question, have you tried restarting the PC?
$immond$
Thanks but when I reach:
ASSIGN
I am unable to assign, I keep getting (Please select a Volume and try again)
My RAID array is DISK 1, and Partition 1 1192.09 Gb
2,644 (0.44/day)
System Name MRCOMP!
Processor 5800X3D
Memory 64GB 3600mhz
Storage 1TB SSD
whoops i missed a step lol.
type in list volume..... your array volume should come up.... if so
type in Select volume 7
assign
let me know if your volume is not there.
2,644 (0.44/day)
System Name MRCOMP!
Processor 5800X3D
Memory 64GB 3600mhz
Storage 1TB SSD
yeah,
if the volume dosnt exist. type in
Select disk 1
Select partition 1
Create Volume simple
EDIT
missed the word simple.
i havnt slept in a few hours.... i have a feeling iv missed somthing.
$immond$
hmm maybe I had it backwards while creating the partition.
lol disk has to be dynamic.. Hmm I am going to see if Nortan Partition Magic can fix this.
2,644 (0.44/day)
System Name MRCOMP!
Processor 5800X3D
Memory 64GB 3600mhz
Storage 1TB SSD
maybe go from the start.. type in
select disk 1
clean
create primary partition
select partition 1
active
format FS=NTFS
assign
exit
if that dosnt work then idk :(
$immond$
I attempted to use my old Partition magic, its not supported in Vista or win 7 :(
$immond$
Alright I corrected the issue I deleted the RAID array and re-created it, I then proceeded to create a partition using diskmgmt.msc and created using GPT and not MBR.
Now windows detects it and it working properly! Thanks anyways I guess the issue was with the partition table.
Thanks anyways. Thread can be closed.
