Disk Striping
826 (0.12/day)
Hello Peoples,
Just got a second 200gb wd to add to my main rig, i was hoping to stripe the two disks,(fast read/write,space)
im unsure how to do this and was hoping someone here would be able to help/advise.....the two disks are identical and i have an asus an832 sli deluxe board with a silicone image controller...and will be running XP pro 64,..
thanks in advance..Craig
Hook them both up, go into the BIOS settings for your motherboard and change the SATA settings to RAID0 instead of just regular sata. There's usually another setup you have to go into outside of the BIOS in order to setup your array. Hope that helps. It's kind of vague, because all motherboards are a little bit different.
Thank wtf,
yeah i had to go deeper into the bios than i thought,
Cheers for the help...Craig
